in my nextcloud app (13.0.4) on Univention (4.3 errata 126) I get a lot of Info and warnings.
Warning user_ldap not suitable default quota found for user fam: []
Info cli Memcache \OC\Memcache\APCu not available for distributed cache
Info cli Memcache \OC\Memcache\APCu not available for local cache
Do I have to set a quota for every user?
Ok, to solve the last one I have to install php7.0-apcu, but its not in the repository.
P.S.: About the latter, could you file an issue at https://github.com/nextcloud/univention-app/issues ? If you’re up for investigating it, or even supply a fix, that would be even better On first sight it does not look complicated. I cannot look into it before August.
