i just freshly installed the latest UCS and then Nextcloud from the appcenter.
The only things i also did was to add an A record (strato) to let a domain point to the machines IP, install and configure letsencrypt via the UCS appcenter, and forced HTTPS in the UCS registry.
Univention management console works fine with a working ssl certificate and all.
Nextcloud also seems to work but it is incredibly slow.
The login page will only appear after quite a wait, and the login itself takes 60 -120 seconds.
Also moving inside nextcloud lags unbearably.
I found some irritating errors in the apache logs of the docker container:
Failed to remove directory /tmp/appimage_extracted_9bc52a5da15b4853d238ef00019d6a4d/usr/share/man/de: Directory not empty
Failed to remove directory /tmp/appimage_extracted_9bc52a5da15b4853d238ef00019d6a4d/usr/share/man: Directory not empty
Failed to remove directory /tmp/appimage_extracted_9bc52a5da15b4853d238ef00019d6a4d/usr/share/upstart/sessions: Directory not empty
Failed to remove directory /tmp/appimage_extracted_9bc52a5da15b4853d238ef00019d6a4d/usr/share/upstart: Directory not empty
Failed to remove directory /tmp/appimage_extracted_9bc52a5da15b4853d238ef00019d6a4d/usr/share: Directory not empty
Failed to remove directory /tmp/appimage_extracted_9bc52a5da15b4853d238ef00019d6a4d/usr/bin: Directory not empty
Failed to remove directory /tmp/appimage_extracted_9bc52a5da15b4853d238ef00019d6a4d/usr: Directory not empty
Failed to remove directory /tmp/appimage_extracted_9bc52a5da15b4853d238ef00019d6a4d: Directory not empty
[Sat Dec 19 23:09:28.307544 2020] [autoindex:error] [pid 69] [client 123.12.12.1:38772] AH01276: Cannot serve directory /var/www/html: No matching Director
yIndex (none) found, and server-generated directory index forbidden by Options directive, referer: https://foo.bar.de/univention/portal/
[Sat Dec 19 23:11:13.168202 2020] [autoindex:error] [pid 43] [client 123.12.12.1:38818] AH01276: Cannot serve directory /var/www/html: No matching Director
Also nextcloud points me to a bunch of issues as well:
Actually i don’t know what to make out of these.
I had actually assumed that Nextcloud should be at least basically usable after an installation from the App Center.
However this doesn’t seem to be the case at all, so perhaps i am missing something?
Any ideas or share of experience welcome
thanks
Sascha
