Nextcloud Update schlägt fehlt
wir wollten auf UCS 5.0 Nextcloud 20.0.10-0 auf 21.0.3-0 updaten - Update bricht aber ab
Hier mal das Log, auf das mich UCS dann hinweist…
17975 cache 21-07-14 16:30:19 [ DEBUG]: Cache outdated. Need to rebuild
17975 cache 21-07-14 16:30:19 [ DEBUG]: Loaded 352 apps from cache
18298 cache 21-07-14 16:30:22 [ DEBUG]: Cache outdated. Need to rebuild
18298 cache 21-07-14 16:30:22 [ DEBUG]: Loaded 17 apps from cache
18298 cache 21-07-14 16:30:22 [ DEBUG]: Loaded 352 apps from cache
18298 cache 21-07-14 16:30:22 [ DEBUG]: Loaded 251 apps from cache
18298 cache 21-07-14 16:30:23 [ DEBUG]: Cache outdated. Need to rebuild
18298 cache 21-07-14 16:30:23 [ DEBUG]: Loaded 352 apps from cache
17975 utils 21-07-14 16:30:25 [ INFO]: Resolving dependencies for nextcloud
17975 actions.update 21-07-14 16:30:26 [ DEBUG]: Calling update
17975 actions.update.progress 21-07-14 16:30:26 [ DEBUG]: 0
17975 actions.update 21-07-14 16:30:26 [ INFO]: Downloading “https://appcenter.software-univention.de/meta-inf/app-categories.ini”…
17975 actions.update 21-07-14 16:30:26 [ DEBUG]: … Not Modified
17975 actions.update 21-07-14 16:30:26 [ INFO]: Downloading “https://appcenter.software-univention.de/meta-inf/rating.ini”…
17975 actions.update 21-07-14 16:30:26 [ INFO]: Downloading “https://appcenter.software-univention.de/meta-inf/license_types.ini”…
17975 actions.update 21-07-14 16:30:26 [ INFO]: Downloading “https://appcenter.software-univention.de/meta-inf/ucs.ini”…
17975 actions.update 21-07-14 16:30:26 [ INFO]: Downloading “https://appcenter.software-univention.de/meta-inf/suggestions.json”…
17975 actions.update 21-07-14 16:30:26 [ INFO]: Downloading “https://appcenter.software-univention.de/meta-inf/5.0/index.json.gz”…
17975 actions.update 21-07-14 16:30:26 [ INFO]: Downloading “https://appcenter.software-univention.de/meta-inf/5.0/index.json.gz.gpg”…
17975 actions.update 21-07-14 16:30:26 [ INFO]: Downloading “https://appcenter.software-univention.de/meta-inf/5.0/all.tar.gpg”…
17975 actions.update 21-07-14 16:30:26 [ INFO]: Downloading “https://appcenter.software-univention.de/meta-inf/4.4/index.json.gz”…
17975 actions.update 21-07-14 16:30:27 [ DEBUG]: … Not Modified
17975 actions.update 21-07-14 16:30:27 [ INFO]: Downloading “https://appcenter.software-univention.de/meta-inf/4.4/index.json.gz.gpg”…
17975 actions.update 21-07-14 16:30:27 [ INFO]: Downloading “https://appcenter.software-univention.de/meta-inf/4.4/all.tar.gpg”…
17975 actions.update 21-07-14 16:30:27 [ INFO]: Downloading “https://appcenter.software-univention.de/meta-inf/4.3/index.json.gz”…
17975 actions.update 21-07-14 16:30:27 [ INFO]: Downloading “https://appcenter.software-univention.de/meta-inf/4.3/index.json.gz.gpg”…
17975 actions.update 21-07-14 16:30:27 [ INFO]: Downloading “https://appcenter.software-univention.de/meta-inf/4.3/all.tar.gpg”…
17975 actions.update.progress 21-07-14 16:30:27 [ DEBUG]: 100
17975 actions.upgrade 21-07-14 16:30:27 [ INFO]: 4.4/nextcloud=21.0.3-0 is a Docker App. No sane dry run is implemented
17975 actions.upgrade 21-07-14 16:30:27 [ DEBUG]: Calling upgrade
17975 actions.upgrade.progress 21-07-14 16:30:27 [ DEBUG]: 0
17975 utils 21-07-14 16:30:27 [ INFO]: Resolving dependencies for nextcloud
17975 actions.upgrade 21-07-14 16:30:27 [ INFO]: Going to upgrade Nextcloud Hub (21.0.3-0)
17975 actions.upgrade 21-07-14 16:30:27 [ INFO]: Showing README for 4.4/nextcloud=21.0.3-0
17975 actions.upgrade 21-07-14 16:30:27 [ DEBUG]: Calling prescript (preinst)
17975 actions.upgrade 21-07-14 16:30:27 [ DEBUG]: Calling /var/cache/univention-appcenter/appcenter.software-univention.de/4.4/nextcloud_20210701143854.preinst --old-version 20.0.10-0 --version 21.0.3-0 --error-file /tmp/tmp157uyu5x --binddn uid=Administrator,cn=users,dc=DE220930,dc=vw-group,dc=com --bindpwdfile /tmp/tmpctop1u83 --locale de
17975 actions.upgrade 21-07-14 16:30:28 [ DEBUG]: /var/cache/univention-appcenter/appcenter.software-univention.de/4.4/nextcloud_20210701143854.preinst returned with 0
17975 packages 21-07-14 16:30:28 [ DEBUG]: Holding LOCK
17975 actions.start 21-07-14 16:30:28 [ DEBUG]: Calling start
17975 actions.start.progress 21-07-14 16:30:28 [ DEBUG]: 0
17975 actions.start 21-07-14 16:30:28 [ DEBUG]: Calling /etc/init.d/docker-app-nextcloud start
17975 actions.start 21-07-14 16:30:28 [ INFO]: Starting docker-app-nextcloud (via systemctl): docker-app-nextcloud.service.
17975 actions.start 21-07-14 16:30:28 [ DEBUG]: /etc/init.d/docker-app-nextcloud returned with 0
17975 actions.start.progress 21-07-14 16:30:28 [ DEBUG]: 100
17975 actions.configure 21-07-14 16:30:28 [ WARNING]: Cannot write settings while 4.4/nextcloud=21.0.3-0 is not running
17975 actions.upgrade 21-07-14 16:30:28 [ INFO]: Executing interface update_available for nextcloud
17975 actions.upgrade 21-07-14 16:30:28 [ INFO]: No interface defined
17975 actions.upgrade 21-07-14 16:30:28 [ INFO]: Upgrading image (‘docker.software-univention.de/nextcloud:21.0.3-0’)
17975 actions.upgrade 21-07-14 16:30:28 [ INFO]: Pulling Docker image docker.software-univention.de/nextcloud:21.0.3-0
17975 actions.upgrade 21-07-14 16:30:28 [ INFO]: Downloading app image docker.software-univention.de/nextcloud:21.0.3-0
17975 docker 21-07-14 16:30:28 [ INFO]: Running command: docker pull docker.software-univention.de/nextcloud:21.0.3-0
17975 docker 21-07-14 16:30:29 [ INFO]: 21.0.3-0: Pulling from nextcloud
17975 docker 21-07-14 16:30:29 [ INFO]: Digest: sha256:20d75c669c64334b18df76e74f716b5b4503a06a9e2115af132dbadba5f466fe
17975 docker 21-07-14 16:30:29 [ INFO]: Status: Image is up to date for docker.software-univention.de/nextcloud:21.0.3-0
17975 docker 21-07-14 16:30:29 [ INFO]: docker.software-univention.de/nextcloud:21.0.3-0
17975 actions.upgrade 21-07-14 16:30:29 [ INFO]: Saving data from old container (4.4/nextcloud=20.0.10-0)
17975 actions.start 21-07-14 16:30:29 [ DEBUG]: Calling start
17975 actions.start.progress 21-07-14 16:30:29 [ DEBUG]: 0
17975 actions.start 21-07-14 16:30:29 [ DEBUG]: Calling /etc/init.d/docker-app-nextcloud start
17975 actions.start 21-07-14 16:30:29 [ INFO]: Starting docker-app-nextcloud (via systemctl): docker-app-nextcloud.service.
17975 actions.start 21-07-14 16:30:29 [ DEBUG]: /etc/init.d/docker-app-nextcloud returned with 0
17975 actions.start.progress 21-07-14 16:30:29 [ DEBUG]: 100
17975 actions.upgrade 21-07-14 16:30:29 [ INFO]: Running command: docker cp 9f8ee38f30a8e0adc2dde4310188d8198f5524006bb4200e5e9cdaeaff999d70:/etc/machine.secret /var/lib/univention-appcenter/apps/nextcloud/machine.secret
17975 actions.upgrade 21-07-14 16:30:29 [ INFO]: Executing interface store_data for nextcloud
17975 actions.upgrade 21-07-14 16:30:29 [ INFO]: Copying App Center’s store_data to container’s /usr/share/univention-docker-container-mode/store_data_custom
17975 actions.upgrade.container.9f8e 21-07-14 16:30:29 [ DEBUG]: Using container.9f8e for container 9f8ee38f30a8e0adc2dde4310188d8198f5524006bb4200e5e9cdaeaff999d70
17975 actions.upgrade.container.9f8e 21-07-14 16:30:29 [ DEBUG]: Calling docker exec -u root 9f8ee38f30a8e0adc2dde4310188d8198f5524006bb4200e5e9cdaeaff999d70 /usr/share/univention-docker-container-mode/store_data_custom --error-file /var/univention/tmp/tmp36z_7bdc --app nextcloud --app-version 20.0.10-0
17975 actions.upgrade.container.9f8e 21-07-14 16:30:30 [ INFO]: failed to start io pipe copy: containerd-shim: opening b60a5fbea156bcce5417de38126111b63a9835053cf7c6bc419993b7f576c3b0-stdout failed: open b60a5fbea156bcce5417de38126111b63a9835053cf7c6bc419993b7f576c3b0-stdout: no such file or directory: unknown
17975 actions.upgrade 21-07-14 16:30:30 [CRITICAL]: Image upgrade script (pre) failed
17975 actions.upgrade 21-07-14 16:30:30 [CRITICAL]: Storing data for 4.4/nextcloud=20.0.10-0 failed
17975 packages 21-07-14 16:30:30 [ DEBUG]: Releasing LOCK
17975 actions.upgrade 21-07-14 16:30:30 [CRITICAL]: Could not backup container!
17975 actions.upgrade 21-07-14 16:30:30 [ WARNING]: Aborting…
17975 actions.start 21-07-14 16:30:30 [ DEBUG]: Calling start
17975 actions.start.progress 21-07-14 16:30:30 [ DEBUG]: 0
17975 actions.start 21-07-14 16:30:30 [ DEBUG]: Calling /etc/init.d/docker-app-nextcloud start
17975 actions.start 21-07-14 16:30:30 [ INFO]: Starting docker-app-nextcloud (via systemctl): docker-app-nextcloud.service.
17975 actions.start 21-07-14 16:30:30 [ DEBUG]: /etc/init.d/docker-app-nextcloud returned with 0
17975 actions.start.progress 21-07-14 16:30:30 [ DEBUG]: 100
17975 utils 21-07-14 16:30:30 [ DEBUG]: send_information: action=upgrade app=nextcloud value=None status=430
17975 utils 21-07-14 16:30:30 [ DEBUG]: tracking information: {‘action’: ‘upgrade’, ‘status’: 430, ‘uuid’: ‘dd194bc1-5447-4375-a334-67242bcc9e97’, ‘role’: ‘domaincontroller_master’, ‘app’: ‘nextcloud’, ‘version’: ‘21.0.3-0’, ‘system-uuid’: ‘fc818e7e-8d7e-4ed4-b542-2fe50ce4ec91’}
17975 actions.upgrade-search 21-07-14 16:30:30 [ DEBUG]: Calling upgrade-search
17975 actions.upgrade-search.progress 21-07-14 16:30:30 [ DEBUG]: 0
17975 actions.upgrade-search 21-07-14 16:30:30 [ DEBUG]: Checking 4.4/nextcloud=21.0.3-0
17975 actions.upgrade-search.progress 21-07-14 16:30:30 [ DEBUG]: 100
17975 actions.upgrade.progress 21-07-14 16:30:30 [ DEBUG]: 100
Wir hatten bis dato (vor 5.0) noch nie Probleme damit und auch sonst nichts verändert.
Vielleicht kann mir hier jemand auf die Sprünge helfen?
Vielen Dank.
C. Ostermayr
