Nextcloud ucs collabora android
nextcloud is running fine on my server. I use it with https://domain.de/nextcloud
I have enabled collabora online and it is working fine in browsers.
But on my android app I dont see the “Open with collabora” button.
If i try to activate “Zugriff auf experimentelle Apps aktivieren” on my server setting the hook always dissapears.
Do you have any ideas?
Best regards,
Stefan
