Nextcloud reverse proxy
I tried to follow:
and
whereas I wasn’t able to get it working with the template file.
So I created /etc/apache2/sites-enabled/nextcloud.conf and pasted following in it:
<IfModule mod_ssl.c>
<VirtualHost *:443>
  ServerAdmin admin@domain.de
  ServerName cloud.domain.de
  DocumentRoot /var/www
  <Directory /var/www>
    Options +FollowSymlinks
    AllowOverride All
    <IfModule mod_dav.c>
      Dav off
    </IfModule>
    SetEnv HOME /var/www
    SetEnv HTTP_HOME /var/www
  </Directory>
  SSLEngine on
  SSLProxyEngine on
  SSLProxyCheckPeerCN off
  SSLProxyCheckPeerName off
  SSLCertificateChainFile /etc/univention/letsencrypt/intermediate.pem
  <IfModule mod_headers.c>
   Header always set Strict-Transport-Security "max-age=15552000; includeSubDomains"
  </IfModule>
  ProxyPass / http://localhost:40000/
  ProxyPassReverse / http://localhost:40000/
</VirtualHost>
</IfModule>
I also modified the config file by
univention-app shell nextcloud
apt update
apt install vim
vim  /var/www/html/config/config.php
  'overwrite.cli.url' => 'https://cloud.domain.de',
  'overwritewbroot' => '/',
  'htaccess.RewriteBase' => '/',
exit
I restarted apache
/etc/init.d/apache2 restart
And type cloud.domain.de
I get redirected to Nextcloud, but it displays an internal server error. I have no idea why.
cloud.domain.de/nextcloud/ works, just as from the beginning on.
What am I doing wrong?
That’s the error from NC:
{"reqId":"YjQY0D752nWmz7ZXujrB","level":3,"time":"2019-02-16T21:39:31+00:00","remoteAddr":"92.116.161.180","user":"--","app":"index","method":"GET","url":"\/login",
"message":{"Exception":"Exception","Message":"The requested uri(\/login) cannot be processed by the script '\/nextcloud\/index.php')","Code":0,"Trace":[{"file":"\/var\/www\/html\/lib\/base.php","line":930,"function":"getRawPathInfo","class":"OC\\AppFramework\\Http\\Request","type":"->","args":[]},{"file":"\/var\/www\/html\/index.php","line":42,"function":"handleRequest","class":"OC","type":"::","args":[]}],"File":"\/var\/www\/html\/lib\/private\/AppFramework\/Http\/Request.php","Line":742,"CustomMessage":"--"},"userAgent":"Mozilla\/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit\/537.36 (KHTML, like Gecko) Chrome\/70.0.3538.102 Safari\/537.36 OPR\/57.0.3098.116","version":"14.0.6.0"}
I didn’t find your error in the files. The only difference I see is the missing retry 0 in the ProxyPass - but I don’t see how this would make such an error. So I ask stupid questions, like:
  • did you restart apache inside the docker-image too?
(don’t forget to edit /var/lib/univention-appcenter/apps/nextcloud/data/integration/config/config.php and chown it correctly: chown www-data:nogroup ... like this you don’t have to redo everything with the next docker update)
I ask the question because, when I type cloud.domain.de/nextcloud into my browser, I get redirected to cloud.domain.de
Bernd
Hey,
I have exactly the same problem! I have done a new installation an the strange behaviour remains. I followed exactly the way described here.
Where do I find the nextcloud logs`
BR
fk
You can find the log files in
/var/lib/univention-appcenter/apps/nextcloud/data/nextcloud-data/nextcloud.log
@lebernd
Thank you for your reply, but the missing retry 0 didn’t fix the problem.
I restartet the docker
service docker-app-nextcloud stop
service docker-app-nextcloud start
or the server, nothing helped.
I must miss something, but I don’t know what.
It was a fresh install in my case, too. Maybe there has been something changed in the docke images?
edit:
I think it’s strange that cloud.domain.de/nextcloud/login still works, even though I modified the config.php file in the docker image, which, as far as I understand, should make this impossible.
Can you post your config.php? are there other/ conflicting rewrite parameters?
Mine looks like this:
<?php
$CONFIG = array (
  'passwordsalt' => 'pwsaltxy',
  'secret' => 'secretxy',
  'trusted_domains' =>
  array (
    0 => 'myucs.intern.domain.de',
    1 => 'private IP',
    2 => 'public IP',
    3 => 'cloud.domain.de',
  'datadirectory' => '/var/lib/univention-appcenter/apps/nextcloud/data/nextcloud-data',
  'dbtype' => 'pgsql',
  'version' => '14.0.6.0',
  'dbname' => 'nextcloud',
  'dbhost' => 'docker gw IP',
  'dbport' => '5432',
  'dbtableprefix' => 'oc_',
  'dbuser' => 'nextcloud',
  'dbpassword' => 'dbpass',
  'installed' => true,
  'instanceid' => 'occ010101',
  'updatechecker' => 'false',
  'memcache.local' => '\\OC\\Memcache\\APCu',
  'overwriteprotocol' => 'https',
  'ldapIgnoreNamingRules' => false,
  'ldapProviderFactory' => '\\OCA\\User_LDAP\\LDAPProviderFactory',
  'trusted_proxies' =>
  array (
    0 => 'docker gw IP',
  'loglevel' => 2,
  'maintenance' => false,
Google is pointing for a similar error to: https://central.owncloud.org/t/the-requested-uri-login-cannot-be-processed-by-the-script-owncloud-index-php/993
the following did the trick for me (thanks @lebernd for pointing to the link) :
dial in the nextcloud containter:
go to /var/www/html and
sudo -u www-data php occ maintenance:update:htaccess
it should give you
.htaccess has been updated
Thank you both for your help.
The solution from fk22 did the trick for me, too. Now it works. Thank you again.
