Nextcloud login problem after upgrade from 20.0.2 to 20.0.8
I did Nextcloud upgrade from 20.0.2 to 20.0.8 and now users can’t login. We can insert login credentials but after we receive an Internal Server Error page with ID request for server administrator.
Looking in /var/lib/univention-appcenter/apps/nextcloud/data/nextcloud-data/nextcloud.log I found this related to the login ID request error code. Is this a bug on nextcloud update? How can I login agin correctly?
{"reqId":"WsoCPuJYTD3kWvkKPemL","level":0,"time":"2021-03-24T08:31:46+00:00","remoteAddr":"192.168.0.177","user":"Administrator","app":"files_sharing","method":"GET","url":"/nextcloud/apps/dashboard/","message":"/appinfo/app.php is deprecated, use \\OCP\\AppFramework\\Bootstrap\\IBootstrap on the application class instead.","userAgent":"Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_6) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/14.0.3 Safari/605.1.15","version":"20.0.8.1"}
{"reqId":"WsoCPuJYTD3kWvkKPemL","level":0,"time":"2021-03-24T08:31:46+00:00","remoteAddr":"192.168.0.177","user":"Administrator","app":"onlyoffice","method":"GET","url":"/nextcloud/apps/dashboard/","message":"/appinfo/app.php is deprecated, use \\OCP\\AppFramework\\Bootstrap\\IBootstrap on the application class instead.","userAgent":"Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_6) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/14.0.3 Safari/605.1.15","version":"20.0.8.1"}
{"reqId":"WsoCPuJYTD3kWvkKPemL","level":3,"time":"2021-03-24T08:31:46+00:00","remoteAddr":"192.168.0.177","user":"Administrator","app":"index","method":"GET","url":"/nextcloud/apps/dashboard/","message":{"Exception":"Doctrine\\DBAL\\Exception\\TableNotFoundException","Message":"An exception occurred while executing 'SELECT \"r\".*, \"p\".* FROM \"oc_talk_rooms\" \"r\" LEFT JOIN \"oc_talk_participants\" \"p\" ON (\"p\".\"user_id\" = ?) AND (\"p\".\"room_id\" = \"r\".\"id\") WHERE \"p\".\"user_id\" IS NOT NULL' with params [\"Administrator\"]:\n\nSQLSTATE[42P01]: Undefined table: 7 ERRORE:  la relazione \"oc_talk_participants\" non esiste\nLINE 1: ...T \"r\".*, \"p\".* FROM \"oc_talk_rooms\" \"r\" LEFT JOIN \"oc_talk_p...\n                                                             ^","Code":0,"Trace":[{"file":"/var/www/html/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/DBALException.php","line":169,"function":"convertException","class":"Doctrine\\DBAL\\Driver\\AbstractPostgreSQLDriver","type":"->"},{"file":"/var/www/html/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/DBALException.php","line":149,"function":"wrapException","class":"Doctrine\\DBAL\\DBALException","type":"::"},{"file":"/var/www/html/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php","line":914,"function":"driverExceptionDuringQuery","class":"Doctrine\\DBAL\\DBALException","type":"::"},{"file":"/var/www/html/lib/private/DB/Connection.php","line":202,"function":"executeQuery","class":"Doctrine\\DBAL\\Connection","type":"->"},{"file":"/var/www/html/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Query/QueryBuilder.php","line":206,"function":"executeQuery","class":"OC\\DB\\Connection","type":"->"},{"file":"/var/www/html/lib/private/DB/QueryBuilder/QueryBuilder.php","line":217,"function":"execute","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->"},{"file":"/var/www/html/apps/spreed/lib/Manager.php","line":294,"function":"execute","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->"},{"file":"/var/www/html/apps/spreed/lib/Share/RoomShareProvider.php","line":779,"function":"getRoomsForParticipant","class":"OCA\\Talk\\Manager","type":"->"},{"file":"/var/www/html/lib/private/Share20/Manager.php","line":1332,"function":"getSharedWith","class":"OCA\\Talk\\Share\\RoomShareProvider","type":"->"},{"file":"/var/www/html/apps/files_sharing/lib/MountProvider.php","line":80,"function":"getSharedWith","class":"OC\\Share20\\Manager","type":"->"},{"file":"/var/www/html/lib/private/Files/Config/MountProviderCollection.php","line":119,"function":"getMountsForUser","class":"OCA\\Files_Sharing\\MountProvider","type":"->"},{"file":"/var/www/html/lib/private/Files/Filesystem.php","line":452,"function":"addMountForUser","class":"OC\\Files\\Config\\MountProviderCollection","type":"->"},{"file":"/var/www/html/lib/private/Files/Filesystem.php","line":377,"function":"initMountPoints","class":"OC\\Files\\Filesystem","type":"::"},{"file":"/var/www/html/lib/private/legacy/OC_Util.php","line":322,"function":"init","class":"OC\\Files\\Filesystem","type":"::"},{"file":"/var/www/html/lib/base.php","line":1007,"function":"setupFS","class":"OC_Util","type":"::"},{"file":"/var/www/html/index.php","line":37,"function":"handleRequest","class":"OC","type":"::"}],"File":"/var/www/html/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Driver/AbstractPostgreSQLDriver.php","Line":63,"Previous":{"Exception":"Doctrine\\DBAL\\Driver\\PDOException","Message":"SQLSTATE[42P01]: Undefined table: 7 ERRORE:  la relazione \"oc_talk_participants\" non esiste\nLINE 1: ...T \"r\".*, \"p\".* FROM \"oc_talk_rooms\" \"r\" LEFT JOIN \"oc_talk_p...\n                                                             ^","Code":"42P01","Trace":[{"file":"/var/www/html/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php","line":906,"function":"execute","class":"Doctrine\\DBAL\\Driver\\PDOStatement","type":"->"},{"file":"/var/www/html/lib/private/DB/Connection.php","line":202,"function":"executeQuery","class":"Doctrine\\DBAL\\Connection","type":"->"},{"file":"/var/www/html/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Query/QueryBuilder.php","line":206,"function":"executeQuery","class":"OC\\DB\\Connection","type":"->"},{"file":"/var/www/html/lib/private/DB/QueryBuilder/QueryBuilder.php","line":217,"function":"execute","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->"},{"file":"/var/www/html/apps/spreed/lib/Manager.php","line":294,"function":"execute","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->"},{"file":"/var/www/html/apps/spreed/lib/Share/RoomShareProvider.php","line":779,"function":"getRoomsForParticipant","class":"OCA\\Talk\\Manager","type":"->"},{"file":"/var/www/html/lib/private/Share20/Manager.php","line":1332,"function":"getSharedWith","class":"OCA\\Talk\\Share\\RoomShareProvider","type":"->"},{"file":"/var/www/html/apps/files_sharing/lib/MountProvider.php","line":80,"function":"getSharedWith","class":"OC\\Share20\\Manager","type":"->"},{"file":"/var/www/html/lib/private/Files/Config/MountProviderCollection.php","line":119,"function":"getMountsForUser","class":"OCA\\Files_Sharing\\MountProvider","type":"->"},{"file":"/var/www/html/lib/private/Files/Filesystem.php","line":452,"function":"addMountForUser","class":"OC\\Files\\Config\\MountProviderCollection","type":"->"},{"file":"/var/www/html/lib/private/Files/Filesystem.php","line":377,"function":"initMountPoints","class":"OC\\Files\\Filesystem","type":"::"},{"file":"/var/www/html/lib/private/legacy/OC_Util.php","line":322,"function":"init","class":"OC\\Files\\Filesystem","type":"::"},{"file":"/var/www/html/lib/base.php","line":1007,"function":"setupFS","class":"OC_Util","type":"::"},{"file":"/var/www/html/index.php","line":37,"function":"handleRequest","class":"OC","type":"::"}],"File":"/var/www/html/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Driver/PDOStatement.php","Line":129,"Previous":{"Exception":"PDOException","Message":"SQLSTATE[42P01]: Undefined table: 7 ERRORE:  la relazione \"oc_talk_participants\" non esiste\nLINE 1: ...T \"r\".*, \"p\".* FROM \"oc_talk_rooms\" \"r\" LEFT JOIN \"oc_talk_p...\n                                                             ^","Code":"42P01","Trace":[{"file":"/var/www/html/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Driver/PDOStatement.php","line":127,"function":"execute","class":"PDOStatement","type":"->"},{"file":"/var/www/html/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Connection.php","line":906,"function":"execute","class":"Doctrine\\DBAL\\Driver\\PDOStatement","type":"->"},{"file":"/var/www/html/lib/private/DB/Connection.php","line":202,"function":"executeQuery","class":"Doctrine\\DBAL\\Connection","type":"->"},{"file":"/var/www/html/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Query/QueryBuilder.php","line":206,"function":"executeQuery","class":"OC\\DB\\Connection","type":"->"},{"file":"/var/www/html/lib/private/DB/QueryBuilder/QueryBuilder.php","line":217,"function":"execute","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->"},{"file":"/var/www/html/apps/spreed/lib/Manager.php","line":294,"function":"execute","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->"},{"file":"/var/www/html/apps/spreed/lib/Share/RoomShareProvider.php","line":779,"function":"getRoomsForParticipant","class":"OCA\\Talk\\Manager","type":"->"},{"file":"/var/www/html/lib/private/Share20/Manager.php","line":1332,"function":"getSharedWith","class":"OCA\\Talk\\Share\\RoomShareProvider","type":"->"},{"file":"/var/www/html/apps/files_sharing/lib/MountProvider.php","line":80,"function":"getSharedWith","class":"OC\\Share20\\Manager","type":"->"},{"file":"/var/www/html/lib/private/Files/Config/MountProviderCollection.php","line":119,"function":"getMountsForUser","class":"OCA\\Files_Sharing\\MountProvider","type":"->"},{"file":"/var/www/html/lib/private/Files/Filesystem.php","line":452,"function":"addMountForUser","class":"OC\\Files\\Config\\MountProviderCollection","type":"->"},{"file":"/var/www/html/lib/private/Files/Filesystem.php","line":377,"function":"initMountPoints","class":"OC\\Files\\Filesystem","type":"::"},{"file":"/var/www/html/lib/private/legacy/OC_Util.php","line":322,"function":"init","class":"OC\\Files\\Filesystem","type":"::"},{"file":"/var/www/html/lib/base.php","line":1007,"function":"setupFS","class":"OC_Util","type":"::"},{"file":"/var/www/html/index.php","line":37,"function":"handleRequest","class":"OC","type":"::"}],"File":"/var/www/html/3rdparty/doctrine/dbal/lib/Doctrine/DBAL/Driver/PDOStatement.php","Line":127}},"CustomMessage":"--"},"userAgent":"Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_6) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/14.0.3 Safari/605.1.15","version":"20.0.8.1"}
There seems to be an issue with Nextcloud Talk: I’ve disabled the app:
univention-app shell nextcloud sudo -u www-data /var/www/html/occ app:disable spreed
Please check whether https://github.com/nextcloud/spreed/issues/5324#issuecomment-791398470 applies
It does indeed - thank you for pointing to this!
I bring this up as I hit the same issue on update 20.0.8 -> 20.0.9
Installing the now available spreed preview-version 10.1.4 (https://github.com/nextcloud/spreed/releases/download/v10.1.4/spreed-10.1.4.tar.gz) is working for me.
