today i installed Nextcloud and wondered why i can’t login. After reading some sites i found out that the join script is not running.
So i found this old thread:
Docker Name Reslotution
Next i entered the docker container and when i ping the ucs server i get the provider IP.
In a further step i changed the /etc/hosts file in the docker to test the solution which was written in the thread. Now i get the local ip when i ping the server but the join script don’t run.
Is it a problem that the domain name is set to xxx.local instead of xxx.de? In the hosts file both names are given.
What can i do to make the Nextcloud run?
Kind regads
Jochen
Check in the UCS - GUI under “User”, whether the user(s) is/are enabled to use Nextcloud.
Thank you for your reply. I checked this before but i think the problem is nextcloud:
univention-check-join-status
Warning: ‘nextcloud’ is not configured.
Error: Not all install files configured: 1 missing
In the join.log i can find this:
Object exists: SAMLServiceProviderIdentifier=https://ucs.xxx.local/nextcloud/apps/user_saml/metadata,cn=saml-serviceprovider,cn=univention,dc=xxx,dc=local
Config value type for app user_saml set to saml
Config value general-require_provisioned_account for app user_saml set to 1
Config value general-allow_multible_user_back_ends for app user_saml set to 1
There are no commands defined in the “saml:config” namespace.
curl failed with error 60
Failed to request an LDAP config id from Nextcloud
Kind regards
Jochen
i have this same issue, did you ever find a fix?
unfortunatly i didn’t find a solution for this issue. I use a NAS storage as workaround.
Kind regards Jochen
