on two another customers we use Nextcloud directly from UCS with SAML. On this new one here we have an existing LXC (Ubuntu 18.04) with Nextcloud 16.04. LDAP and User are converted and this works great. but if we enable SAML and configured that the same schema like the other customers witch UCS, it did not work. @Login it says “no Metadata”.
And the other strange thing, after an reboot of the LXC, the saml app in nextcloud is automaticly disabled.
Yes, we have done all customers with this howto. The difference is the Nextcloud from UCS points to for example: https://cloud.supertux.lan/nextcloud
The Cloud here opens directly on https://cloud.supertux.lan. So have done the same configuration but without the path “/nextcloud”. If i open some link, this is working. Like Metadata…
Ok. So i’ve deleted every configuration and configured the whole SSO for nextlcoud new. Same thing, same error, did not work. New installation - Nextcloud on UCS, did work. So what?
One good thing, the samlapp is enabled after reboot normally. And where i can find Logs, about errors in saml from nextcloud the did me help to find the solution?
It’s a configuration thing then. Compare both SAML settings side by side. There are also some collapsed fields on that settings page. You also set up the SP configuration within UCS, right?
