Nextcloud lässt sich nicht installieren
Ich hätte nextcloud gerne getestet.
Leider lässt sich die App nicht installieren.
Habe ein neues UCS-System aufgesetzt und als Domain-Slave gejoined. Bis hierhin ist alles gut.
Wenn ich nun versuche nextcloud zu installieren bricht die installation mit folgenden Meldung ab:
UCS Version: 4.2-2 errata52 (Lesum)
Die Ausführung des Kommandos appcenter/docker/progress ist fehlgeschlagen:
primaryGroup: cn=Computers,cn=groups,dc=hs-bremerhaven,dc=de
raise univention.admin.uexceptions.primaryGroup(self[‘primaryGroup’])
File “/usr/lib/pymodules/python2.7/univention/admin/handlers/init.py”, line 537, in get_gid_for_primary_group
gidNum = self.get_gid_for_primary_group()
File “/usr/lib/pymodules/python2.7/univention/admin/handlers/computers/memberserver.py”, line 481, in _ldap_addlist
al = self._ldap_addlist()
File “/usr/lib/pymodules/python2.7/univention/admin/handlers/init.py”, line 771, in _create
dn = self._create(response=response, serverctrls=serverctrls)
File “/usr/lib/pymodules/python2.7/univention/admin/handlers/init.py”, line 324, in create
obj.create()
File “/usr/lib/pymodules/python2.7/univention/appcenter/udm.py”, line 97, in create_object_if_not_exists
obj = create_object_if_not_exists(‘computers/%s’ % app.docker_server_role, lo, pos, name=hostname, description=description, domain=domain, password=password, objectFlag=‘docker’, policies=policies)
File “/usr/lib/pymodules/python2.7/univention/appcenter/actions/register.py”, line 285, in _register_host
hostdn, password = self._register_host(app, args)
File “/usr/lib/pymodules/python2.7/univention/appcenter/actions/docker_install.py”, line 57, in _install_app
if self._install_app(app, args):
File “/usr/lib/pymodules/python2.7/univention/appcenter/actions/install.py”, line 87, in _do_it
ret = super(Install, self)._do_it(app, args)
File “/usr/lib/pymodules/python2.7/univention/appcenter/actions/docker_install.py”, line 65, in _do_it
self._do_it(app, args)
File “/usr/lib/pymodules/python2.7/univention/appcenter/actions/install_base.py”, line 126, in do_it
return self.do_it(args)
File “/usr/lib/pymodules/python2.7/univention/appcenter/actions/install.py”, line 70, in main
result = self.main(namespace)
File “/usr/lib/pymodules/python2.7/univention/appcenter/actions/init.py”, line 245, in call_with_namespace
return obj.call_with_namespace(namespace)
File “/usr/lib/pymodules/python2.7/univention/appcenter/actions/init.py”, line 239, in call
result[‘success’] = action.call(app=app, username=self.username, password=self.password, **kwargs)
File “/usr/lib/pymodules/python2.7/univention/management/console/modules/appcenter/init.py”, line 417, in invoke_docker
yield function(self, *args)
File “/usr/lib/pymodules/python2.7/univention/management/console/modules/decorators.py”, line 286, in _fake_func
return list(function(self, iterator, *nones))
File “/usr/lib/pymodules/python2.7/univention/management/console/modules/decorators.py”, line 440, in _response
return function(self, request)
File “/usr/lib/pymodules/python2.7/univention/management/console/modules/decorators.py”, line 192, in _response
result = _multi_response(self, request)
File “/usr/lib/pymodules/python2.7/univention/management/console/modules/decorators.py”, line 309, in _thread
ret = progress_obj.poll()
File “/usr/lib/pymodules/python2.7/univention/management/console/modules/mixins.py”, line 149, in progress
File “/usr/lib/pymodules/python2.7/univention/management/console/modules/decorators.py”, line 318, in _response
function.func(self, request, *args, **kwargs)
File “/usr/lib/pymodules/python2.7/univention/management/console/base.py”, line 249, in execute
Hat jemand eine Idee was falsch gelaufen ist??
PS:
Beim Versuch owncloud zu installieren kommt es zu ähnlichen Fehlermeldungen
Gruß
Henry
mir ist nicht klar, wie es dazu kam, aber die Gruppe “Computers” scheint nicht zu existieren. Sie ist eigentlich standardmäßig eingerichtet bei UCS-Systemen.
Wurde die Gruppe mal gelöscht, verschoben, umbenannt?
Viele Grüße
Dirk Wiesenthal
Meines wisses nicht Wo muss ich sie anlegen??
habe eben nachgesehen . Auf dem master ist eine Gruppe Domain Computers vorhanden.
Guten Tag @zbrv,
bitte prüfen Sie mit dem folgenden Befehl:
# univention-ldapsearch cn=Computers
ob die Gruppe “Computers” existiert.
Posten Sie bitte zusätzlich die Ausgabe von
# univention-ldapsearch objectClass=univentionDefault
Wenn es die Gruppen nicht gibt, so können Sie diese mit dem folgenden Befehl erstellen:
# udm groups/group create --position "cn=groups,$(ucr get ldap/base)" --set name=Computers  --append nestedGroup="cn=DC Backup Hosts,cn=groups,$(ucr get ldap/base)" --append nestedGroup="cn=DC Slave Hosts,cn=groups,$(ucr get ldap/base)"
Danach können Sie die Nextcloud Installation neu starten.
Grüß
Anna Takang
Ganz lieben Dank, das hat jetzt wunderbar geklappt
