There is a similar error reported in German, but my German knowledge is too rusty to take on the challenge to reply there.
Essentially I also tried to add nextcloud to my UCS and could not make the join script to complete.
I tried the solution offered in the other thread but did not help for me.
I also manually installed the missing univention-ldap-overlay-memberof deb but it did not help.
To confirm that there is nothing wrong with my server, just the package is the issue, I installed a fresh UCS server in a virtual environment and then added nextcloud as the only package. The join script did not complete there either.
See attached error log for reference
5a1f117b OVER: Loading Translog Overlay
5a1f117b Loading shadowbind Overlay.OVER: db_init
5a1f117b OVER: Configuring Translog Overlay
5a1f117b OVER: Configured Translog Overlay to use file "/var/lib/univention-ldap/listener/listener"
5a1f117b shadowbind_db_init
5a1f117b shadowbind_db_config
5a1f117b shadowbind_db_open
5a1f117e OVER: db_close
5a1f117e shadowbind_db_destroy
5a1f117e OVER: db_destroy
Wed Nov 29 15:15:26 EST 2017
RUNNING 01univention-ldap-server-init.inst
EXITCODE=already_executed
RUNNING 02univention-directory-notifier.inst
RUNNING 03univention-directory-listener.inst
RUNNING 04univention-ldap-client.inst
RUNNING 05univention-bind.inst
RUNNING 08univention-apache.inst
RUNNING 10univention-ldap-server.inst
RUNNING 11univention-heimdal-init.inst
RUNNING 11univention-pam.inst
RUNNING 15univention-directory-notifier-post.inst
RUNNING 15univention-heimdal-kdc.inst
RUNNING 18python-univention-directory-manager.inst
RUNNING 20univention-directory-policy.inst
RUNNING 20univention-join.inst
RUNNING 26univention-nagios-common.inst
RUNNING 30univention-appcenter.inst
RUNNING 30univention-nagios-client.inst
RUNNING 31univention-nagios-ad-connector.inst
RUNNING 33univention-portal.inst
RUNNING 34univention-management-console-server.inst
RUNNING 35univention-appcenter-docker.inst
RUNNING 35univention-management-console-module-adconnector.inst
RUNNING 35univention-management-console-module-appcenter.inst
RUNNING 35univention-management-console-module-diagnostic.inst
RUNNING 35univention-management-console-module-ipchange.inst
RUNNING 35univention-management-console-module-join.inst
RUNNING 35univention-management-console-module-lib.inst
RUNNING 35univention-management-console-module-mrtg.inst
RUNNING 35univention-management-console-module-quota.inst
RUNNING 35univention-management-console-module-reboot.inst
RUNNING 35univention-management-console-module-services.inst
RUNNING 35univention-management-console-module-setup.inst
RUNNING 35univention-management-console-module-sysinfo.inst
RUNNING 35univention-management-console-module-top.inst
RUNNING 35univention-management-console-module-ucr.inst
RUNNING 35univention-management-console-module-udm.inst
RUNNING 35univention-management-console-module-updater.inst
RUNNING 35univention-server-overview.inst
RUNNING 36univention-management-console-module-apps.inst
RUNNING 40univention-virtual-machine-manager-schema.inst
RUNNING 81univention-ad-connector.inst
RUNNING 81univention-nfs-server.inst
RUNNING 90univention-bind-post.inst
RUNNING 91univention-saml.inst
RUNNING 92univention-management-console-web-server.inst
Wed Nov 29 15:15:27 EST 2017
Wed Nov 29 15:24:43 EST 2017
Wed Nov 29 15:24:44 EST 2017
Wed Nov 29 15:57:14 EST 2017
RUNNING 40univention-postgresql.inst
RUNNING 50nextcloud.inst
2017-11-29 15:57:23.170870714-05:00 (in joinscript_init)
Object exists: cn=services,cn=univention,dc=example,dc=net
Object created: cn=Nextcloud,cn=services,cn=univention,dc=example,dc=net
Object modified: cn=ucs-1012,cn=dc,cn=computers,dc=example,dc=net
Create nextcloud/ucs/modifyUsersFilter
Create nextcloud/ucs/userEnabled
Create nextcloud/ucs/userQuota
Create nextcloud/ldap/cacheTTL
Create nextcloud/ldap/homeFolderAttribute
Create nextcloud/ldap/userSearchAttributes
Create nextcloud/ldap/userDisplayName
Create nextcloud/ldap/groupDisplayName
Create nextcloud/ldap/base
Create nextcloud/ldap/baseUsers
Create nextcloud/ldap/baseGroups
Create nextcloud/ldap/filterLogin
Create nextcloud/ldap/filterUsers
Create nextcloud/ldap/filterGroups
dpkg-query: no packages found matching univention-ldap-overlay-memberof
Object exists: cn=ldapschema,cn=univention,dc=example,dc=net
INFO: No change of core data of object nextcloud.
No modification: cn=nextcloud,cn=ldapschema,cn=univention,dc=example,dc=net
Waiting for activation of the extension object nextcloud: OK
Object created: cn=nextcloud,cn=custom attributes,cn=univention,dc=example,dc=net
Object created: cn=nextcloudUserEnabled,cn=nextcloud,cn=custom attributes,cn=univention,dc=example,dc=net
Object created: cn=nextcloudUserQuota,cn=nextcloud,cn=custom attributes,cn=univention,dc=example,dc=net
Object created: cn=nextcloudGroupEnabled,cn=nextcloud,cn=custom attributes,cn=univention,dc=example,dc=net
curl: (3) <url> malformed
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0 0 173 0 0 0 0 0 0 --:--:-- 0:00:01 --:--:-- 0 100 173 100 173 0 0 167 0 0:00:01 0:00:01 --:--:-- 167
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0 92 1725 0 0 100 1587 0 3436 --:--:-- --:--:-- --:--:-- 3435 100 1725 100 138 100 1587 298 3434 --:--:-- --:--:-- --:--:-- 3435
modifying uid=Administrator,cn=users,dc=example,dc=net ..
Object modified: uid=Administrator,cn=users,dc=example,dc=net
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0 100 300 100 300 0 0 1475 0 --:--:-- --:--:-- --:--:-- 1477
Could not Administrator to admin group, because user was not found:
<?xml version="1.0"?> <ocs> <meta> <status>failure</status> <statuscode>404</statuscode> <message>Invalid query, please check the syntax. API specifications are here: http://www.freedesktop.org/wiki/Specifications/open-collaboration-services. DEBUG OUTPUT: </message> </meta> <data/> </ocs>
EXITCODE=0
Wed Nov 29 15:57:31 EST 2017
Wed Nov 29 16:16:54 EST 2017
2017-11-29 16:17:01.911792500-05:00 (in joinscript_init)
Object exists: cn=Nextcloud,cn=services,cn=univention,dc=example,dc=net
WARNING: cannot append Nextcloud to service, value exists
No modification: cn=ucs-1012,cn=dc,cn=computers,dc=example,dc=net
Not updating nextcloud/ucs/modifyUsersFilter
Not updating nextcloud/ucs/userEnabled
Not updating nextcloud/ucs/userQuota
Not updating nextcloud/ldap/cacheTTL
Not updating nextcloud/ldap/homeFolderAttribute
Not updating nextcloud/ldap/userSearchAttributes
Not updating nextcloud/ldap/userDisplayName
Not updating nextcloud/ldap/groupDisplayName
Not updating nextcloud/ldap/base
Not updating nextcloud/ldap/baseUsers
Not updating nextcloud/ldap/baseGroups
Not updating nextcloud/ldap/filterLogin
Not updating nextcloud/ldap/filterUsers
Not updating nextcloud/ldap/filterGroups
Object exists: cn=nextcloud,cn=custom attributes,cn=univention,dc=example,dc=net
E: Object exists: cn=nextcloudUserEnabled,cn=nextcloud,cn=custom attributes,cn=univention,dc=example,dc=net
No modification: cn=nextcloudUserEnabled,cn=nextcloud,cn=custom attributes,cn=univention,dc=example,dc=net
E: Object exists: cn=nextcloudUserQuota,cn=nextcloud,cn=custom attributes,cn=univention,dc=example,dc=net
No modification: cn=nextcloudUserQuota,cn=nextcloud,cn=custom attributes,cn=univention,dc=example,dc=net
E: Object exists: cn=nextcloudGroupEnabled,cn=nextcloud,cn=custom attributes,cn=univention,dc=example,dc=net
Object modified: cn=nextcloudGroupEnabled,cn=nextcloud,cn=custom attributes,cn=univention,dc=example,dc=net
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0 100 300 100 300 0 0 2103 0 --:--:-- --:--:-- --:--:-- 2112
EXITCODE=0
Wed Nov 29 16:17:07 EST 2017
