Nextcloud Install stuck at ->
i install nextcloud on a new Server. I didnt do anything on this server. Fresh installed. No other Apps installed.
I stuck here over 10 minutes:
2020-03-09%2010_17_59-connect_c-lab_nightvision%40ad%20-%20AnyDesk
/var/log/univention# tail -f management-console-module-appcenter.log
09.03.20 10:14:33.202 MODULE ( PROCESS ) : Executing interface restore_data_before_setup for nextcloud
09.03.20 10:14:33.243 MODULE ( PROCESS ) : Copying App Center’s restore_data_before_setup to container’s /usr/share/univention-docker-container-mode/restore_data_before_setup_custom
09.03.20 10:14:33.477 MODULE ( PROCESS ) : Executing interface setup for nextcloud
09.03.20 10:14:33.517 MODULE ( PROCESS ) : Copying App Center’s setup to container’s /usr/share/univention-docker-container-mode/setup_custom
09.03.20 10:14:33.660 MODULE ( PROCESS ) :
09.03.20 10:14:33.663 MODULE ( PROCESS ) : Updating certificates in /etc/ssl/certs…
09.03.20 10:16:15.022 MODULE ( PROCESS ) : Setting auth type to None
09.03.20 10:18:45.051 MODULE ( PROCESS ) : Setting auth type to None
09.03.20 10:21:15.067 MODULE ( PROCESS ) : Setting auth type to None
09.03.20 10:23:45.090 MODULE ( PROCESS ) : Setting auth type to None
/var/log/univention# tail -f appcenter.log
15648 actions.install 20-03-09 10:14:33 [ INFO]: Executing interface restore_data_before_setup for nextcloud
15648 actions.install 20-03-09 10:14:33 [ INFO]: Copying App Center’s restore_data_before_setup to container’s /usr/share/univention-docker-container-mode/restore_data_before_setup_custom
15648 actions.install.container.5bc8 20-03-09 10:14:33 [ DEBUG]: Using container.5bc8 for container 5bc89e62b2aa696e2c901366249ffcc34bc1ef123c25cdbb2b3ef5bde23d1da9
15648 actions.install.container.5bc8 20-03-09 10:14:33 [ DEBUG]: Calling docker exec -u root 5bc89e62b2aa696e2c901366249ffcc34bc1ef123c25cdbb2b3ef5bde23d1da9 /usr/share/univention-docker-container-mode/restore_data_before_setup_custom --app nextcloud --app-version 18.0.1-0 --error-file /var/univention/tmp/tmpwqrMIF
15648 actions.install 20-03-09 10:14:33 [ INFO]: Executing interface setup for nextcloud
15648 actions.install 20-03-09 10:14:33 [ INFO]: Copying App Center’s setup to container’s /usr/share/univention-docker-container-mode/setup_custom
15648 actions.install.container.5bc8 20-03-09 10:14:33 [ DEBUG]: Calling docker exec -u root 5bc89e62b2aa696e2c901366249ffcc34bc1ef123c25cdbb2b3ef5bde23d1da9 /usr/share/univention-docker-container-mode/setup_custom --username Administrator --app nextcloud --error-file /var/univention/tmp/tmpDwqO_d --password-file /var/univention/tmp/tmpr7f0jU --app-version 18.0.1-0
15648 actions.install.container.5bc8 20-03-09 10:14:33 [ WARNING]:
15648 actions.install.container.5bc8 20-03-09 10:14:33 [ WARNING]: Updating certificates in /etc/ssl/certs…
Any ideas? Is this normal on V18?
Best Regards
Corin
