I m a beginner and installed nextcloud.
After some hours I found out that I ve to configuthe the trusted domain for my use-case in the docker container.
My question is where and how is configured that all changes and files are persistend?
Ralf
thanks. I found this out earlier this day. The question is where the persistance of the container is configured.
ralf
In the config.php - as you could see it.
hi ralf,
maybe you talking about persistent volumes?
Please help me to understand.
kind regards
