I’m testing Nextcloud on UCS. I want to access the $HOME shares via Nextcloud.
This is the configuration (I’ve translated it myself from german):
Authentication: “Save credentials in session”
Server: FQDN of the server
Share: homes
External folder: /
Domain: Netbios domain name
Unluckily it’s not working. The message is “Received empty response from server”.
I’ve evaluated it a little bot more. The problem seems the name of the share (“homes”). In Nextcloud it’s working if I use a specific user name as share name instead. In Windows I also can’t access the share “homes”.
This setup is working in an other non-UCS SAMBA-AD domain. But there is no difference between the share configurations of my UCS domain and the other non-UCS domain.
EDIT: I’ve found a solution in the documentation. I use now “$user” as share name.
