NextCloud External smb\cifs connection point failure
SMB/CIFS share’s are on Freenas
SMB shares available from Windows and Kopano.
But In Next-cloud I receive the message Mount Point Connection Failure.
Hopefully one off you can tell me how I can solve this issue.
Maybe someone can if you post relevant lines from /var/lib/univention-appcenter/apps/nextcloud/data/nextcloud-data/nextcloud.log.
Thanks for your response, I was me not aware that there is also a log file available.
{"reqId":"FnVa6aahklwFGY72tq93","level":3,"time":"2018-10-03T20:52:55+00:00","remoteAddr":"10.0.0.179","user":"user1","app":"no app in context","method":"PROPFIND","url":"\/nextcloud\/remote.php\/webdav","message":"Error while getting file info: {\"Exception\":\"Icewind\\\\SMB\\\\Exception\\\\TimedOutException\",\"Message\":\"\\\/\",\"Code\":110,\"Trace\":\"#0 \\\/var\\\/www\\\/html\\\/apps\\\/files_external\\\/3rdparty\\\/icewind\\\/smb\\\/src\\\/NativeState.php(49): Icewind\\\\SMB\\\\Exception\\\\Exception::fromMap(Array, 110, '\\\/')\\n#1 \\\/var\\\/www\\\/html\\\/apps\\\/files_external\\\/3rdparty\\\/icewind\\\/smb\\\/src\\\/NativeState.php(61): Icewind\\\\SMB\\\\NativeState->handleError('\\\/')\\n#2 \\\/var\\\/www\\\/html\\\/apps\\\/files_external\\\/3rdparty\\\/icewind\\\/smb\\\/src\\\/NativeState.php(170): Icewind\\\\SMB\\\\NativeState->testResult(false, 'smb:\\\/\\\/fileserver\\\/So...')\\n#3 \\\/var\\\/www\\\/html\\\/apps\\\/files_external\\\/3rdparty\\\/icewind\\\/smb\\\/src\\\/NativeShare.php(107): Icewind\\\\SMB\\\\NativeState->stat('smb:\\\/\\\/fileserver\\\/So...')\\n#4 \\\/var\\\/www\\\/html\\\/apps\\\/files_external\\\/3rdparty\\\/icewind\\\/smb\\\/src\\\/NativeShare.php(103): Icewind\\\\SMB\\\\NativeShare->getStat('\\\/')\\n#5 \\\/var\\\/www\\\/html\\\/apps\\\/files_external\\\/lib\\\/Lib\\\/Storage\\\/SMB.php(141): Icewind\\\\SMB\\\\NativeShare->stat('\\\/')\\n#6 \\\/var\\\/www\\\/html\\\/apps\\\/files_external\\\/lib\\\/Lib\\\/Storage\\\/SMB.php(241): OCA\\\\Files_External\\\\Lib\\\\Storage\\\\SMB->getFileInfo('\\\/')\\n#7 \\\/var\\\/www\\\/html\\\/lib\\\/private\\\/Files\\\/Storage\\\/Common.php(449): OCA\\\\Files_External\\\\Lib\\\\Storage\\\\SMB->stat('')\\n#8 \\\/var\\\/www\\\/html\\\/apps\\\/files_external\\\/lib\\\/Lib\\\/Storage\\\/SMB.php(555): OC\\\\Files\\\\Storage\\\\Common->test()\\n#9 \\\/var\\\/www\\\/html\\\/lib\\\/private\\\/Files\\\/Storage\\\/Wrapper\\\/Wrapper.php(471): OCA\\\\Files_External\\\\Lib\\\\Storage\\\\SMB->test()\\n#10 \\\/var\\\/www\\\/html\\\/lib\\\/private\\\/Files\\\/Storage\\\/Wrapper\\\/Wrapper.php(471): OC\\\\Files\\\\Storage\\\\Wrapper\\\\Wrapper->test()\\n#11 \\\/var\\\/www\\\/html\\\/lib\\\/private\\\/Files\\\/Storage\\\/Wrapper\\\/Wrapper.php(471): OC\\\\Files\\\\Storage\\\\Wrapper\\\\Wrapper->test()\\n#12 \\\/var\\\/www\\\/html\\\/lib\\\/private\\\/Files\\\/Storage\\\/Wrapper\\\/Availability.php(55): OC\\\\Files\\\\Storage\\\\Wrapper\\\\Wrapper->test()\\n#13 \\\/var\\\/www\\\/html\\\/lib\\\/private\\\/Files\\\/Storage\\\/Wrapper\\\/Availability.php(69): OC\\\\Files\\\\Storage\\\\Wrapper\\\\Availability->updateAvailability()\\n#14 \\\/var\\\/www\\\/html\\\/lib\\\/private\\\/Files\\\/Storage\\\/Wrapper\\\/Availability.php(78): OC\\\\Files\\\\Storage\\\\Wrapper\\\\Availability->isAvailable()\\n#15 \\\/var\\\/www\\\/html\\\/lib\\\/private\\\/Files\\\/Storage\\\/Wrapper\\\/Availability.php(461): OC\\\\Files\\\\Storage\\\\Wrapper\\\\Availability->checkAvailability()\\n#16 \\\/var\\\/www\\\/html\\\/lib\\\/private\\\/Files\\\/Storage\\\/Wrapper\\\/Wrapper.php(581): OC\\\\Files\\\\Storage\\\\Wrapper\\\\Availability->getMetaData('')\\n#17 \\\/var\\\/www\\\/html\\\/lib\\\/private\\\/Files\\\/Storage\\\/Wrapper\\\/Wrapper.php(581): OC\\\\Files\\\\Storage\\\\Wrapper\\\\Wrapper->getMetaData('')\\n#18 \\\/var\\\/www\\\/html\\\/lib\\\/private\\\/Files\\\/Storage\\\/Wrapper\\\/Wrapper.php(581): OC\\\\Files\\\\Storage\\\\Wrapper\\\\Wrapper->getMetaData('')\\n#19 \\\/var\\\/www\\\/html\\\/lib\\\/private\\\/Files\\\/Storage\\\/Wrapper\\\/Wrapper.php(581): OC\\\\Files\\\\Storage\\\\Wrapper\\\\Wrapper->getMetaData('')\\n#20 \\\/var\\\/www\\\/html\\\/lib\\\/private\\\/Files\\\/Cache\\\/Scanner.php(112): OC\\\\Files\\\\Storage\\\\Wrapper\\\\Wrapper->getMetaData('')\\n#21 \\\/var\\\/www\\\/html\\\/lib\\\/private\\\/Files\\\/Cache\\\/Scanner.php(150): OC\\\\Files\\\\Cache\\\\Scanner->getData('')\\n#22 \\\/var\\\/www\\\/html\\\/lib\\\/private\\\/Files\\\/View.php(1458): OC\\\\Files\\\\Cache\\\\Scanner->scanFile('')\\n#23 \\\/var\\\/www\\\/html\\\/apps\\\/dav\\\/lib\\\/Connector\\\/Sabre\\\/Directory.php(265): OC\\\\Files\\\\View->getDirectoryContent('\\\/')\\n#24 \\\/var\\\/www\\\/html\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Tree.php(195): OCA\\\\DAV\\\\Connector\\\\Sabre\\\\Directory->getChildren()\\n#25 \\\/var\\\/www\\\/html\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(899): Sabre\\\\DAV\\\\Tree->getChildren('')\\n#26 \\\/var\\\/www\\\/html\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(978): Sabre\\\\DAV\\\\Server->generatePathNodes(Object(Sabre\\\\DAV\\\\PropFind), Array)\\n#27 \\\/var\\\/www\\\/html\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(1666): Sabre\\\\DAV\\\\Server->getPropertiesIteratorForPath('', Array, 1)\\n#28 \\\/var\\\/www\\\/html\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/CorePlugin.php(359): Sabre\\\\DAV\\\\Server->generateMultiStatus(Object(Generator), false)\\n#29 [internal function]: Sabre\\\\DAV\\\\CorePlugin->httpPropFind(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#30 \\\/var\\\/www\\\/html\\\/3rdparty\\\/sabre\\\/event\\\/lib\\\/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\\n#31 \\\/var\\\/www\\\/html\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(479): Sabre\\\\Event\\\\EventEmitter->emit('method:PROPFIND', Array)\\n#32 \\\/var\\\/www\\\/html\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(254): Sabre\\\\DAV\\\\Server->invokeMethod(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#33 \\\/var\\\/www\\\/html\\\/apps\\\/dav\\\/appinfo\\\/v1\\\/webdav.php(80): Sabre\\\\DAV\\\\Server->exec()\\n#34 \\\/var\\\/www\\\/html\\\/remote.php(164): require_once('\\\/var\\\/www\\\/html\\\/a...')\\n#35 {main}\",\"File\":\"\\\/var\\\/www\\\/html\\\/apps\\\/files_external\\\/3rdparty\\\/icewind\\\/smb\\\/src\\\/Exception\\\/Exception.php\",\"Line\":30}","userAgent":"Mozilla\/5.0 (Windows NT 10.0; Win64; x64; rv:62.0) Gecko\/20100101 Firefox\/62.0","version":"13.0.6.1"}
{"reqId":"FnVa6aahklwFGY72tq93","level":3,"time":"2018-10-03T20:52:55+00:00","remoteAddr":"10.0.0.179","user":"user1","app":"no app in context","method":"PROPFIND","url":"\/nextcloud\/remote.php\/webdav","message":"Error while getting file info: {\"Exception\":\"Icewind\\\\SMB\\\\Exception\\\\TimedOutException\",\"Message\":\"\\\/muziek\",\"Code\":110,\"Trace\":\"#0 \\\/var\\\/www\\\/html\\\/apps\\\/files_external\\\/3rdparty\\\/icewind\\\/smb\\\/src\\\/NativeState.php(49): Icewind\\\\SMB\\\\Exception\\\\Exception::fromMap(Array, 110, '\\\/muziek')\\n#1 \\\/var\\\/www\\\/html\\\/apps\\\/files_external\\\/3rdparty\\\/icewind\\\/smb\\\/src\\\/NativeState.php(61): Icewind\\\\SMB\\\\NativeState->handleError('\\\/muziek')\\n#2 \\\/var\\\/www\\\/html\\\/apps\\\/files_external\\\/3rdparty\\\/icewind\\\/smb\\\/src\\\/NativeState.php(170): Icewind\\\\SMB\\\\NativeState->testResult(false, 'smb:\\\/\\\/fileserver\\\/mu...')\\n#3 \\\/var\\\/www\\\/html\\\/apps\\\/files_external\\\/3rdparty\\\/icewind\\\/smb\\\/src\\\/NativeShare.php(107): Icewind\\\\SMB\\\\NativeState->stat('smb:\\\/\\\/fileserver\\\/mu...')\\n#4 \\\/var\\\/www\\\/html\\\/apps\\\/files_external\\\/3rdparty\\\/icewind\\\/smb\\\/src\\\/NativeShare.php(103): Icewind\\\\SMB\\\\NativeShare->getStat('\\\/muziek')\\n#5 \\\/var\\\/www\\\/html\\\/apps\\\/files_external\\\/lib\\\/Lib\\\/Storage\\\/SMB.php(141): Icewind\\\\SMB\\\\NativeShare->stat('\\\/muziek')\\n#6 \\\/var\\\/www\\\/html\\\/apps\\\/files_external\\\/lib\\\/Lib\\\/Storage\\\/SMB.php(241): OCA\\\\Files_External\\\\Lib\\\\Storage\\\\SMB->getFileInfo('\\\/muziek')\\n#7 \\\/var\\\/www\\\/html\\\/lib\\\/private\\\/Files\\\/Storage\\\/Common.php(449): OCA\\\\Files_External\\\\Lib\\\\Storage\\\\SMB->stat('')\\n#8 \\\/var\\\/www\\\/html\\\/apps\\\/files_external\\\/lib\\\/Lib\\\/Storage\\\/SMB.php(555): OC\\\\Files\\\\Storage\\\\Common->test()\\n#9 \\\/var\\\/www\\\/html\\\/lib\\\/private\\\/Files\\\/Storage\\\/Wrapper\\\/Wrapper.php(471): OCA\\\\Files_External\\\\Lib\\\\Storage\\\\SMB->test()\\n#10 \\\/var\\\/www\\\/html\\\/lib\\\/private\\\/Files\\\/Storage\\\/Wrapper\\\/Wrapper.php(471): OC\\\\Files\\\\Storage\\\\Wrapper\\\\Wrapper->test()\\n#11 \\\/var\\\/www\\\/html\\\/lib\\\/private\\\/Files\\\/Storage\\\/Wrapper\\\/Wrapper.php(471): OC\\\\Files\\\\Storage\\\\Wrapper\\\\Wrapper->test()\\n#12 \\\/var\\\/www\\\/html\\\/lib\\\/private\\\/Files\\\/Storage\\\/Wrapper\\\/Availability.php(55): OC\\\\Files\\\\Storage\\\\Wrapper\\\\Wrapper->test()\\n#13 \\\/var\\\/www\\\/html\\\/lib\\\/private\\\/Files\\\/Storage\\\/Wrapper\\\/Availability.php(69): OC\\\\Files\\\\Storage\\\\Wrapper\\\\Availability->updateAvailability()\\n#14 \\\/var\\\/www\\\/html\\\/lib\\\/private\\\/Files\\\/Storage\\\/Wrapper\\\/Availability.php(78): OC\\\\Files\\\\Storage\\\\Wrapper\\\\Availability->isAvailable()\\n#15 \\\/var\\\/www\\\/html\\\/lib\\\/private\\\/Files\\\/Storage\\\/Wrapper\\\/Availability.php(461): OC\\\\Files\\\\Storage\\\\Wrapper\\\\Availability->checkAvailability()\\n#16 \\\/var\\\/www\\\/html\\\/lib\\\/private\\\/Files\\\/Storage\\\/Wrapper\\\/Wrapper.php(581): OC\\\\Files\\\\Storage\\\\Wrapper\\\\Availability->getMetaData('')\\n#17 \\\/var\\\/www\\\/html\\\/lib\\\/private\\\/Files\\\/Storage\\\/Wrapper\\\/Wrapper.php(581): OC\\\\Files\\\\Storage\\\\Wrapper\\\\Wrapper->getMetaData('')\\n#18 \\\/var\\\/www\\\/html\\\/lib\\\/private\\\/Files\\\/Storage\\\/Wrapper\\\/Wrapper.php(581): OC\\\\Files\\\\Storage\\\\Wrapper\\\\Wrapper->getMetaData('')\\n#19 \\\/var\\\/www\\\/html\\\/lib\\\/private\\\/Files\\\/Storage\\\/Wrapper\\\/Wrapper.php(581): OC\\\\Files\\\\Storage\\\\Wrapper\\\\Wrapper->getMetaData('')\\n#20 \\\/var\\\/www\\\/html\\\/lib\\\/private\\\/Files\\\/Cache\\\/Scanner.php(112): OC\\\\Files\\\\Storage\\\\Wrapper\\\\Wrapper->getMetaData('')\\n#21 \\\/var\\\/www\\\/html\\\/lib\\\/private\\\/Files\\\/Cache\\\/Scanner.php(150): OC\\\\Files\\\\Cache\\\\Scanner->getData('')\\n#22 \\\/var\\\/www\\\/html\\\/lib\\\/private\\\/Files\\\/View.php(1458): OC\\\\Files\\\\Cache\\\\Scanner->scanFile('')\\n#23 \\\/var\\\/www\\\/html\\\/apps\\\/dav\\\/lib\\\/Connector\\\/Sabre\\\/Directory.php(265): OC\\\\Files\\\\View->getDirectoryContent('\\\/')\\n#24 \\\/var\\\/www\\\/html\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Tree.php(195): OCA\\\\DAV\\\\Connector\\\\Sabre\\\\Directory->getChildren()\\n#25 \\\/var\\\/www\\\/html\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(899): Sabre\\\\DAV\\\\Tree->getChildren('')\\n#26 \\\/var\\\/www\\\/html\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(978): Sabre\\\\DAV\\\\Server->generatePathNodes(Object(Sabre\\\\DAV\\\\PropFind), Array)\\n#27 \\\/var\\\/www\\\/html\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(1666): Sabre\\\\DAV\\\\Server->getPropertiesIteratorForPath('', Array, 1)\\n#28 \\\/var\\\/www\\\/html\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/CorePlugin.php(359): Sabre\\\\DAV\\\\Server->generateMultiStatus(Object(Generator), false)\\n#29 [internal function]: Sabre\\\\DAV\\\\CorePlugin->httpPropFind(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#30 \\\/var\\\/www\\\/html\\\/3rdparty\\\/sabre\\\/event\\\/lib\\\/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\\n#31 \\\/var\\\/www\\\/html\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(479): Sabre\\\\Event\\\\EventEmitter->emit('method:PROPFIND', Array)\\n#32 \\\/var\\\/www\\\/html\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(254): Sabre\\\\DAV\\\\Server->invokeMethod(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#33 \\\/var\\\/www\\\/html\\\/apps\\\/dav\\\/appinfo\\\/v1\\\/webdav.php(80): Sabre\\\\DAV\\\\Server->exec()\\n#34 \\\/var\\\/www\\\/html\\\/remote.php(164): require_once('\\\/var\\\/www\\\/html\\\/a...')\\n#35 {main}\",\"File\":\"\\\/var\\\/www\\\/html\\\/apps\\\/files_external\\\/3rdparty\\\/icewind\\\/smb\\\/src\\\/Exception\\\/Exception.php\",\"Line\":30}","userAgent":"Mozilla\/5.0 (Windows NT 10.0; Win64; x64; rv:62.0) Gecko\/20100101 Firefox\/62.0","version":"13.0.6.1"}
{"reqId":"TpzfliPK1TDTGD9CeAib","level":3,"time":"2018-10-03T20:52:55+00:00","remoteAddr":"10.0.0.179","user":"user1","app":"no app in context","method":"GET","url":"\/nextcloud\/index.php\/apps\/files_external\/globalstorages\/11?testOnly=true","message":"Error while getting file info: {\"Exception\":\"Icewind\\\\SMB\\\\Exception\\\\TimedOutException\",\"Message\":\"\\\/\",\"Code\":110,\"Trace\":\"#0 \\\/var\\\/www\\\/html\\\/apps\\\/files_external\\\/3rdparty\\\/icewind\\\/smb\\\/src\\\/NativeState.php(49): Icewind\\\\SMB\\\\Exception\\\\Exception::fromMap(Array, 110, '\\\/')\\n#1 \\\/var\\\/www\\\/html\\\/apps\\\/files_external\\\/3rdparty\\\/icewind\\\/smb\\\/src\\\/NativeState.php(61): Icewind\\\\SMB\\\\NativeState->handleError('\\\/')\\n#2 \\\/var\\\/www\\\/html\\\/apps\\\/files_external\\\/3rdparty\\\/icewind\\\/smb\\\/src\\\/NativeState.php(170): Icewind\\\\SMB\\\\NativeState->testResult(false, 'smb:\\\/\\\/fileserver\\\/So...')\\n#3 \\\/var\\\/www\\\/html\\\/apps\\\/files_external\\\/3rdparty\\\/icewind\\\/smb\\\/src\\\/NativeShare.php(107): Icewind\\\\SMB\\\\NativeState->stat('smb:\\\/\\\/fileserver\\\/So...')\\n#4 \\\/var\\\/www\\\/html\\\/apps\\\/files_external\\\/3rdparty\\\/icewind\\\/smb\\\/src\\\/NativeShare.php(103): Icewind\\\\SMB\\\\NativeShare->getStat('\\\/')\\n#5 \\\/var\\\/www\\\/html\\\/apps\\\/files_external\\\/lib\\\/Lib\\\/Storage\\\/SMB.php(141): Icewind\\\\SMB\\\\NativeShare->stat('\\\/')\\n#6 \\\/var\\\/www\\\/html\\\/apps\\\/files_external\\\/lib\\\/Lib\\\/Storage\\\/SMB.php(241): OCA\\\\Files_External\\\\Lib\\\\Storage\\\\SMB->getFileInfo('\\\/')\\n#7 \\\/var\\\/www\\\/html\\\/lib\\\/private\\\/Files\\\/Storage\\\/Common.php(449): OCA\\\\Files_External\\\\Lib\\\\Storage\\\\SMB->stat('')\\n#8 \\\/var\\\/www\\\/html\\\/apps\\\/files_external\\\/lib\\\/Lib\\\/Storage\\\/SMB.php(555): OC\\\\Files\\\\Storage\\\\Common->test()\\n#9 \\\/var\\\/www\\\/html\\\/apps\\\/files_external\\\/lib\\\/config.php(234): OCA\\\\Files_External\\\\Lib\\\\Storage\\\\SMB->test(false, true)\\n#10 \\\/var\\\/www\\\/html\\\/apps\\\/files_external\\\/lib\\\/Controller\\\/StoragesController.php(256): OC_Mount_Config::getBackendStatus('\\\\\\\\OCA\\\\\\\\Files_Exte...', Array, false, true)\\n#11 \\\/var\\\/www\\\/html\\\/apps\\\/files_external\\\/lib\\\/Controller\\\/StoragesController.php(305): OCA\\\\Files_External\\\\Controller\\\\StoragesController->updateStorageStatus(Object(OCA\\\\Files_External\\\\Lib\\\\StorageConfig), true)\\n#12 [internal function]: OCA\\\\Files_External\\\\Controller\\\\StoragesController->show(11, true)\\n#13 \\\/var\\\/www\\\/html\\\/lib\\\/private\\\/AppFramework\\\/Http\\\/Dispatcher.php(161): call_user_func_array(Array, Array)\\n#14 \\\/var\\\/www\\\/html\\\/lib\\\/private\\\/AppFramework\\\/Http\\\/Dispatcher.php(91): OC\\\\AppFramework\\\\Http\\\\Dispatcher->executeController(Object(OCA\\\\Files_External\\\\Controller\\\\GlobalStoragesController), 'show')\\n#15 \\\/var\\\/www\\\/html\\\/lib\\\/private\\\/AppFramework\\\/App.php(115): OC\\\\AppFramework\\\\Http\\\\Dispatcher->dispatch(Object(OCA\\\\Files_External\\\\Controller\\\\GlobalStoragesController), 'show')\\n#16 \\\/var\\\/www\\\/html\\\/lib\\\/private\\\/AppFramework\\\/Routing\\\/RouteActionHandler.php(47): OC\\\\AppFramework\\\\App::main('OCA\\\\\\\\Files_Exter...', 'show', Object(OC\\\\AppFramework\\\\DependencyInjection\\\\DIContainer), Array)\\n#17 [internal function]: OC\\\\AppFramework\\\\Routing\\\\RouteActionHandler->__invoke(Array)\\n#18 \\\/var\\\/www\\\/html\\\/lib\\\/private\\\/Route\\\/Router.php(297): call_user_func(Object(OC\\\\AppFramework\\\\Routing\\\\RouteActionHandler), Array)\\n#19 \\\/var\\\/www\\\/html\\\/lib\\\/base.php(999): OC\\\\Route\\\\Router->match('\\\/apps\\\/files_ext...')\\n#20 \\\/var\\\/www\\\/html\\\/index.php(42): OC::handleRequest()\\n#21 {main}\",\"File\":\"\\\/var\\\/www\\\/html\\\/apps\\\/files_external\\\/3rdparty\\\/icewind\\\/smb\\\/src\\\/Exception\\\/Exception.php\",\"Line\":30}","userAgent":"Mozilla\/5.0 (Windows NT 10.0; Win64; x64; rv:62.0) Gecko\/20100101 Firefox\/62.0","version":"13.0.6.1"}
{"reqId":"KVM3isdBxfRjpUqyJDK6","level":3,"time":"2018-10-03T20:52:55+00:00","remoteAddr":"10.0.0.179","user":"user1","app":"no app in context","method":"GET","url":"\/nextcloud\/index.php\/apps\/files_external\/globalstorages\/16?testOnly=true","message":"Error while getting file info: {\"Exception\":\"Icewind\\\\SMB\\\\Exception\\\\TimedOutException\",\"Message\":\"\\\/muziek\",\"Code\":110,\"Trace\":\"#0 \\\/var\\\/www\\\/html\\\/apps\\\/files_external\\\/3rdparty\\\/icewind\\\/smb\\\/src\\\/NativeState.php(49): Icewind\\\\SMB\\\\Exception\\\\Exception::fromMap(Array, 110, '\\\/muziek')\\n#1 \\\/var\\\/www\\\/html\\\/apps\\\/files_external\\\/3rdparty\\\/icewind\\\/smb\\\/src\\\/NativeState.php(61): Icewind\\\\SMB\\\\NativeState->handleError('\\\/muziek')\\n#2 \\\/var\\\/www\\\/html\\\/apps\\\/files_external\\\/3rdparty\\\/icewind\\\/smb\\\/src\\\/NativeState.php(170): Icewind\\\\SMB\\\\NativeState->testResult(false, 'smb:\\\/\\\/fileserver\\\/mu...')\\n#3 \\\/var\\\/www\\\/html\\\/apps\\\/files_external\\\/3rdparty\\\/icewind\\\/smb\\\/src\\\/NativeShare.php(107): Icewind\\\\SMB\\\\NativeState->stat('smb:\\\/\\\/fileserver\\\/mu...')\\n#4 \\\/var\\\/www\\\/html\\\/apps\\\/files_external\\\/3rdparty\\\/icewind\\\/smb\\\/src\\\/NativeShare.php(103): Icewind\\\\SMB\\\\NativeShare->getStat('\\\/muziek')\\n#5 \\\/var\\\/www\\\/html\\\/apps\\\/files_external\\\/lib\\\/Lib\\\/Storage\\\/SMB.php(141): Icewind\\\\SMB\\\\NativeShare->stat('\\\/muziek')\\n#6 \\\/var\\\/www\\\/html\\\/apps\\\/files_external\\\/lib\\\/Lib\\\/Storage\\\/SMB.php(241): OCA\\\\Files_External\\\\Lib\\\\Storage\\\\SMB->getFileInfo('\\\/muziek')\\n#7 \\\/var\\\/www\\\/html\\\/lib\\\/private\\\/Files\\\/Storage\\\/Common.php(449): OCA\\\\Files_External\\\\Lib\\\\Storage\\\\SMB->stat('')\\n#8 \\\/var\\\/www\\\/html\\\/apps\\\/files_external\\\/lib\\\/Lib\\\/Storage\\\/SMB.php(555): OC\\\\Files\\\\Storage\\\\Common->test()\\n#9 \\\/var\\\/www\\\/html\\\/apps\\\/files_external\\\/lib\\\/config.php(234): OCA\\\\Files_External\\\\Lib\\\\Storage\\\\SMB->test(false, true)\\n#10 \\\/var\\\/www\\\/html\\\/apps\\\/files_external\\\/lib\\\/Controller\\\/StoragesController.php(256): OC_Mount_Config::getBackendStatus('\\\\\\\\OCA\\\\\\\\Files_Exte...', Array, false, true)\\n#11 \\\/var\\\/www\\\/html\\\/apps\\\/files_external\\\/lib\\\/Controller\\\/StoragesController.php(305): OCA\\\\Files_External\\\\Controller\\\\StoragesController->updateStorageStatus(Object(OCA\\\\Files_External\\\\Lib\\\\StorageConfig), true)\\n#12 [internal function]: OCA\\\\Files_External\\\\Controller\\\\StoragesController->show(16, true)\\n#13 \\\/var\\\/www\\\/html\\\/lib\\\/private\\\/AppFramework\\\/Http\\\/Dispatcher.php(161): call_user_func_array(Array, Array)\\n#14 \\\/var\\\/www\\\/html\\\/lib\\\/private\\\/AppFramework\\\/Http\\\/Dispatcher.php(91): OC\\\\AppFramework\\\\Http\\\\Dispatcher->executeController(Object(OCA\\\\Files_External\\\\Controller\\\\GlobalStoragesController), 'show')\\n#15 \\\/var\\\/www\\\/html\\\/lib\\\/private\\\/AppFramework\\\/App.php(115): OC\\\\AppFramework\\\\Http\\\\Dispatcher->dispatch(Object(OCA\\\\Files_External\\\\Controller\\\\GlobalStoragesController), 'show')\\n#16 \\\/var\\\/www\\\/html\\\/lib\\\/private\\\/AppFramework\\\/Routing\\\/RouteActionHandler.php(47): OC\\\\AppFramework\\\\App::main('OCA\\\\\\\\Files_Exter...', 'show', Object(OC\\\\AppFramework\\\\DependencyInjection\\\\DIContainer), Array)\\n#17 [internal function]: OC\\\\AppFramework\\\\Routing\\\\RouteActionHandler->__invoke(Array)\\n#18 \\\/var\\\/www\\\/html\\\/lib\\\/private\\\/Route\\\/Router.php(297): call_user_func(Object(OC\\\\AppFramework\\\\Routing\\\\RouteActionHandler), Array)\\n#19 \\\/var\\\/www\\\/html\\\/lib\\\/base.php(999): OC\\\\Route\\\\Router->match('\\\/apps\\\/files_ext...')\\n#20 \\\/var\\\/www\\\/html\\\/index.php(42): OC::handleRequest()\\n#21 {main}\",\"File\":\"\\\/var\\\/www\\\/html\\\/apps\\\/files_external\\\/3rdparty\\\/icewind\\\/smb\\\/src\\\/Exception\\\/Exception.php\",\"Line\":30}","userAgent":"Mozilla\/5.0 (Windows NT 10.0; Win64; x64; rv:62.0) Gecko\/20100101 Firefox\/62.0","version":"13.0.6.1"}
{"reqId":"zoCDboTjJmY5K5GkyzT3","level":3,"time":"2018-10-03T20:53:06+00:00","remoteAddr":"10.0.0.179","user":"user1","app":"no app in context","method":"PUT","url":"\/nextcloud\/index.php\/apps\/files_external\/globalstorages\/16","message":"Error while getting file info: {\"Exception\":\"Icewind\\\\SMB\\\\Exception\\\\TimedOutException\",\"Message\":\"\\\/muziek\",\"Code\":110,\"Trace\":\"#0 \\\/var\\\/www\\\/html\\\/apps\\\/files_external\\\/3rdparty\\\/icewind\\\/smb\\\/src\\\/NativeState.php(49): Icewind\\\\SMB\\\\Exception\\\\Exception::fromMap(Array, 110, '\\\/muziek')\\n#1 \\\/var\\\/www\\\/html\\\/apps\\\/files_external\\\/3rdparty\\\/icewind\\\/smb\\\/src\\\/NativeState.php(61): Icewind\\\\SMB\\\\NativeState->handleError('\\\/muziek')\\n#2 \\\/var\\\/www\\\/html\\\/apps\\\/files_external\\\/3rdparty\\\/icewind\\\/smb\\\/src\\\/NativeState.php(170): Icewind\\\\SMB\\\\NativeState->testResult(false, 'smb:\\\/\\\/fileserver\\\/mu...')\\n#3 \\\/var\\\/www\\\/html\\\/apps\\\/files_external\\\/3rdparty\\\/icewind\\\/smb\\\/src\\\/NativeShare.php(107): Icewind\\\\SMB\\\\NativeState->stat('smb:\\\/\\\/fileserver\\\/mu...')\\n#4 \\\/var\\\/www\\\/html\\\/apps\\\/files_external\\\/3rdparty\\\/icewind\\\/smb\\\/src\\\/NativeShare.php(103): Icewind\\\\SMB\\\\NativeShare->getStat('\\\/muziek')\\n#5 \\\/var\\\/www\\\/html\\\/apps\\\/files_external\\\/lib\\\/Lib\\\/Storage\\\/SMB.php(141): Icewind\\\\SMB\\\\NativeShare->stat('\\\/muziek')\\n#6 \\\/var\\\/www\\\/html\\\/apps\\\/files_external\\\/lib\\\/Lib\\\/Storage\\\/SMB.php(241): OCA\\\\Files_External\\\\Lib\\\\Storage\\\\SMB->getFileInfo('\\\/muziek')\\n#7 \\\/var\\\/www\\\/html\\\/lib\\\/private\\\/Files\\\/Storage\\\/Common.php(449): OCA\\\\Files_External\\\\Lib\\\\Storage\\\\SMB->stat('')\\n#8 \\\/var\\\/www\\\/html\\\/apps\\\/files_external\\\/lib\\\/Lib\\\/Storage\\\/SMB.php(555): OC\\\\Files\\\\Storage\\\\Common->test()\\n#9 \\\/var\\\/www\\\/html\\\/apps\\\/files_external\\\/lib\\\/config.php(234): OCA\\\\Files_External\\\\Lib\\\\Storage\\\\SMB->test(false, true)\\n#10 \\\/var\\\/www\\\/html\\\/apps\\\/files_external\\\/lib\\\/Controller\\\/StoragesController.php(256): OC_Mount_Config::getBackendStatus('\\\\\\\\OCA\\\\\\\\Files_Exte...', Array, false, true)\\n#11 \\\/var\\\/www\\\/html\\\/apps\\\/files_external\\\/lib\\\/Controller\\\/GlobalStoragesController.php(179): OCA\\\\Files_External\\\\Controller\\\\StoragesController->updateStorageStatus(Object(OCA\\\\Files_External\\\\Lib\\\\StorageConfig), true)\\n#12 [internal function]: OCA\\\\Files_External\\\\Controller\\\\GlobalStoragesController->update(16, 'muziek', 'smb', 'password::sessi...', Array, Array, Array, Array, 100, true)\\n#13 \\\/var\\\/www\\\/html\\\/lib\\\/private\\\/AppFramework\\\/Http\\\/Dispatcher.php(161): call_user_func_array(Array, Array)\\n#14 \\\/var\\\/www\\\/html\\\/lib\\\/private\\\/AppFramework\\\/Http\\\/Dispatcher.php(91): OC\\\\AppFramework\\\\Http\\\\Dispatcher->executeController(Object(OCA\\\\Files_External\\\\Controller\\\\GlobalStoragesController), 'update')\\n#15 \\\/var\\\/www\\\/html\\\/lib\\\/private\\\/AppFramework\\\/App.php(115): OC\\\\AppFramework\\\\Http\\\\Dispatcher->dispatch(Object(OCA\\\\Files_External\\\\Controller\\\\GlobalStoragesController), 'update')\\n#16 \\\/var\\\/www\\\/html\\\/lib\\\/private\\\/AppFramework\\\/Routing\\\/RouteActionHandler.php(47): OC\\\\AppFramework\\\\App::main('OCA\\\\\\\\Files_Exter...', 'update', Object(OC\\\\AppFramework\\\\DependencyInjection\\\\DIContainer), Array)\\n#17 [internal function]: OC\\\\AppFramework\\\\Routing\\\\RouteActionHandler->__invoke(Array)\\n#18 \\\/var\\\/www\\\/html\\\/lib\\\/private\\\/Route\\\/Router.php(297): call_user_func(Object(OC\\\\AppFramework\\\\Routing\\\\RouteActionHandler), Array)\\n#19 \\\/var\\\/www\\\/html\\\/lib\\\/base.php(999): OC\\\\Route\\\\Router->match('\\\/apps\\\/files_ext...')\\n#20 \\\/var\\\/www\\\/html\\\/index.php(42): OC::handleRequest()\\n#21 {main}\",\"File\":\"\\\/var\\\/www\\\/html\\\/apps\\\/files_external\\\/3rdparty\\\/icewind\\\/smb\\\/src\\\/Exception\\\/Exception.php\",\"Line\":30}","userAgent":"Mozilla\/5.0 (Windows NT 10.0; Win64; x64; rv:62.0) Gecko\/20100101 Firefox\/62.0","version":"13.0.6.1"}
the smb test tool show me the following
Configuration
Hostname	User	Workgroup	Password	Share
Result
Using backend: php-smbclient
Error while loading share content.
Icewind\SMB\Exception\TimedOutException: /
    /var/www/html/apps/files_external/3rdparty/icewind/smb/src/NativeState.php - line 49:
    Icewind\SMB\Exception\Exception::fromMap({ 1: "\\Icew ... "}, 110, "/")
    /var/www/html/apps/files_external/3rdparty/icewind/smb/src/NativeState.php - line 61:
    Icewind\SMB\NativeState->handleError("/")
    /var/www/html/apps/files_external/3rdparty/icewind/smb/src/NativeState.php - line 91:
    Icewind\SMB\NativeState->testResult(false, "smb://fileserver/muziek")
    /var/www/html/apps/files_external/3rdparty/icewind/smb/src/NativeShare.php - line 86:
    Icewind\SMB\NativeState->opendir("smb://fileserver/muziek")
    /var/www/html/apps/smb_test/lib/Controller/SmbController.php - line 95:
    Icewind\SMB\NativeShare->dir("")
    OCA\SMBTest\Controller\SmbController->dir("fileserver", "domain\\user1", "domain", "Password", Icewind\SMB\NativeShare {}, "")
    /var/www/html/lib/private/AppFramework/Http/Dispatcher.php - line 161:
    call_user_func_array([ OCA\SMBTes ... "], [ "fileserver"," ... "])
    /var/www/html/lib/private/AppFramework/Http/Dispatcher.php - line 91:
    OC\AppFramework\Http\Dispatcher->executeController(OCA\SMBTest\ ... {}, "dir")
    /var/www/html/lib/private/AppFramework/App.php - line 115:
    OC\AppFramework\Http\Dispatcher->dispatch(OCA\SMBTest\ ... {}, "dir")
    /var/www/html/lib/private/AppFramework/Routing/RouteActionHandler.php - line 47:
    OC\AppFramework\App::main("OCA\\SMBTes ... r", "dir", OC\AppFramew ... {}, { _route: "smb_test.smb.dir"})
    OC\AppFramework\Routing\RouteActionHandler->__invoke({ _route: "smb_test.smb.dir"})
    /var/www/html/lib/private/Route/Router.php - line 297:
    call_user_func(OC\AppFramew ... {}, { _route: "smb_test.smb.dir"})
    /var/www/html/lib/base.php - line 999:
    OC\Route\Router->match("/apps/smb_test/dir")
    /var/www/html/index.php - line 42:
    OC::handleRequest()
I just found this error message as well on the S4 Connector rejects :
S4 DN: CN=FILESERVER.DOMAIN.NET,CN=Computers,DC=domain,DC=net, UCS DN: not found
We tried already to resync, but that didn’t work.
Then we remove, the file server, and rejoin them again, with the same result.
The file-server is a FreeNas system.
Is there nobody, which one could help me to resolve this issue?
Hey,
with S4 connect rejects you also have corresponding error messages in the log file /var/log/univention/connector-s4.log. Please post those error messages, too.
Ideally what I’d like to know is the very first error message relating to that server, meaning back when it was joined first, not just the last error message from today.
Kind regards
mosu
Thanks for your response.
01.10.2018 23:49:41,808 LDAP        (PROCESS): sync to ucs:   [windowscomputer] [       add] cn=FileServer.Domain.net,CN=Computers,dc=Domain,dc=net
01.10.2018 23:49:41,808 MAIN        (------ ): UNIVENTION_DEBUG_BEGIN : LockingDB.lock_s4
01.10.2018 23:49:41,814 MAIN        (------ ): UNIVENTION_DEBUG_END   : LockingDB.lock_s4
01.10.2018 23:49:41,814 MAIN        (------ ): UNIVENTION_DEBUG_BEGIN : ldap.add_in_ucs
01.10.2018 23:49:41,815 MAIN        (------ ): UNIVENTION_DEBUG_BEGIN : ldap.__set_value
01.10.2018 23:49:41,838 LDAP        (ERROR  ): InvalidSyntax: Windows workstation/server name: Value may not contain other than numbers, letters and dots! (cn=FileServer.Domain.net,CN=Computers,dc=Domain,dc=net)
01.10.2018 23:49:41,838 MAIN        (------ ): UNIVENTION_DEBUG_END   : ldap.__set_value
01.10.2018 23:49:41,838 MAIN        (------ ): UNIVENTION_DEBUG_END   : ldap.add_in_ucs
01.10.2018 23:49:41,839 MAIN        (------ ): UNIVENTION_DEBUG_END   : ldap.sync_to_ucs
01.10.2018 23:49:41,839 LDAP        (WARNING): sync to ucs was not successfull, save rejected
01.10.2018 23:49:41,839 LDAP        (WARNING): object was: CN=FileServer.Domain.net,CN=Computers,DC=Domain,DC=net
01.10.2018 23:49:46,930 MAIN        (------ ): UNIVENTION_DEBUG_END   : ldap.get_ucs_object
01.10.2018 23:49:46,930 LDAP        (PROCESS): sync to ucs:   [           dns] [       add] relativeDomainName=FileServer.Domain.net,zoneName=Domain.net,cn=dns,dc=Domain,dc=net
01.10.2018 23:49:46,931 MAIN        (------ ): UNIVENTION_DEBUG_BEGIN : LockingDB.lock_s4
01.10.2018 23:49:46,955 MAIN        (------ ): UNIVENTION_DEBUG_END   : LockingDB.lock_s4
01.10.2018 23:49:46,955 MAIN        (------ ): UNIVENTION_DEBUG_BEGIN : dns: con2ucs
01.10.2018 23:49:46,955 MAIN        (------ ): UNIVENTION_DEBUG_BEGIN : _identify_dns_con_object
01.10.2018 23:49:46,955 MAIN        (------ ): UNIVENTION_DEBUG_END   : _identify_dns_con_object
Please let me know if you need more info.
Your NAS tries to join with a fully-qualified hostname of FileServer.Domain.net. This is wrong. It must only join with the hostname FileServer. Maybe you can reconfigure your NAS so that it thinks its hostname is FilesServer instead of FileServer.Domain.Net.
I’ve removed the file server from the domain, and add them back to the domain.
The error message from the s4connector is solved with this task.
Unfortunately this didn’t solve the Nextcloud external data issue.
All SMB share’s works form each windows or Linux system, but failed from NextCloud, and Sonos.
Can you run the smb test tool again and see if the error message is the same? “Timeout” indicates that Nextcloud cannot reach the server providing the Samba share for some reason. If it’s still the same error, we will have to look into networking issues.
The smb test show me still exact the same error message.
Is there an option to test the connectivity between the docker, and the FileServer?
So I can run a test when I’m in the docker, (when I run: “univention-app shell nextcloud”)
Can it be, a DNS issue? In the device manager I see the NextCloud docker nextc-63931794. From the server console, I can ping them only by his IP Address, but his name.
The name of the Docker container hosts don’t need to be resolvable. It’s the other way around: the Docker container must be able to resolve the host name of your file server.
You can run a couple of tests:
# Enter the container:
# Install 'ping' and 'smbclient' because it isn't installed yet:
apt-get install iputils-ping smbclient
# Verify DNS resolution & network reachability (use full host name here):
ping fileserver.your.domain
# Try connecting to the share:
smbclient //fileserver.your.domain/sharename -U 'domain\username'
Post the relevant output from ping and smbclient.
m.
Thanks for all your support.
I found the solution on the Freenas forum
afbeelding
When I read this site correct, smb2 will be available in version 14:
Do one of you know when it’s available on Univention?
I’ve got a similar problem.
I cannot mount external storage via SMB that is hosted on a FreeNAS box.
UCS and nextcloud app are up to date (UCS: 4.4.1 errata 273 Nextcloud: 16.0.4-0)
FreeNAS is also up to date (11.2 U6)
I can mount shares hosted on Windows machines but not hosted on FreeNAS
Accessing the FreeNAS shares from windows clients with the same user works fine
At first I thought it might also be SMB1 related but I tried to mount an external storage on a Win10 with smb1 disabled and it works.
Any Ideas?
Cheers
Michael
