Hi@all,
i have installed Nextcloud on a UCS member and today i installed a NC update via UCS ( 18.0.7-0 ) Since then NC does not work anymore. When I try to log in comes:
Where can I find the login data for the database?
with best
sven
Hi@all,
with best
sven
You should find the relevant information with:
cat /var/lib/univention-appcenter/apps/nextcloud/data/integration/config/config.php
Did you check the appcenter.log file for errors?
Best, Bernd
