we prefer to use English here, let me knwo if this is an issue for you.
I installed UCS 4.3 today. Applications NextCloud and for Service the ClamAV and the Demon. In the NextCloud I installed and configured the AntiVirus App. But I have the problem that no ClamAV is used in the Docker Container - am I missing something?
If I set up the clamAV there with univention-app shell nextcloud, the NextCloud AV app runs normally and the TestVirus is detected, but that can’t possibly be the right way?
I am unsure what you have tried, but reading the Nextcloud docs states there are three modes available for the Nextcloud App.
So you have installed the Nextcloud AV-App, right? Inside Docker?
As software inside Docker are seen as a seperate host then the Docker host itself they need to use network based connection to talk to each other.
So your way would be according to Nextcloud Docs:
- Use ClamAV inside Docker Image as aaemon or executable (my understanding this is what you have)
- Use ClamAV on a different server as daemon (this is what you want).
To get 2 you have to configure your NetxCloud App for Mode 2 ( “ClamAV is running on a different server. This is a good option for Nextcloud servers with high volumes of file uploads.”)
Configure you NExtCloudApp accordingly and it should work.
Maybe you might have to configure the UCS-ClamAV App to accept connections from the local network.
/CV
