I have had nextcloud up and running successfully for months. It appears that the 18.0.4 update has broken access to the postgresql database.
Now, when I try to reach the nextcloud server via the webpage: https://myserver/nextcloud, I get to the nextcloud installation page.
I need some guidance on getting the database with all of my existing data back up and running!
Thank you!
root@sp-svr01:~# sudo univention-app info
UCS: 4.4-4 errata587
Installed: bareos=18.2.7
fetchmail=6.3.26
kopano-core=8.7.1.0-1
kopano-webapp=3.5.5.2276
kopano-webmeetings=3.0.1.100
letsencrypt=1.2.2-8
onlyoffice-ds=5.5.1.76
self-service=4.0
self-service-backend=4.0
wekan=4.01
z-push-kopano=2.4.5 4.3
kopano-meet=2.1.0_0-3 4.3
openid-connect-provider=1.1-konnect-0.23.3 4.3
openproject=10.4.0 4.3
rocketchat=3.0.2 4.1
nextcloud=18.0.4-0
Upgradable:
nextcloud.log file with lots of:
{“reqId”:“Y8cOhXaYITflfUxtdYIM”,“level”:3,“time”:“2020-05-12T14:10:01+00:00”,“remoteAddr”:"",“user”:"–",“app”:“cron”,“method”:"",“url”:"–",“message”:{“Exception”:“Exception”,“Message”:“Not installed”,“Code”:0,“Trace”:[{“file”:"/var/www/html/lib/base.php",“line”:651,“function”:“checkInstalled”,“class”:“OC”,“type”:"::",“args”:[]},{“file”:"/var/www/html/lib/base.php",“line”:1089,“function”:“init”,“class”:“OC”,“type”:"::",“args”:[]},{“file”:"/var/www/html/cron.php",“line”:42,“args”:["/var/www/html/lib/base.php"],“function”:“require_once”}],“File”:"/var/www/html/lib/base.php",“Line”:282,“CustomMessage”:"–"},“userAgent”:"–",“version”:“18.0.4.2”}
