New UCS with LetsEncrypt Problem
Just installed my first UCS Server. Installation with new (.local) Domain.
Very satisfied how easy and functional UCS is. NICE JOB !!! WELL DONE !!!
Tested several Apps - nice and easy Installation and Handling. Now i wanted to
access via WEB from external (created a subdomain on my web hoster - ucs.DOMAIN.de, dyndns set up and portforwarding done.) Now i want to secure it via Let’s Encrypt certificate.
Now i have the problem with the local domain created by ucs setup (ucsxxxx.localdomain.local)
Certainly this cannot be certified by LE, just wanted to set the ucs.DOMAIN.de via Let’sEncrypt
Is this possible?
Christian
Yes, there is a setup menu where you can specify the domains for let’s encrypt.
Yes, via App-Settings of Let’s Encrypt APP.
already set up.
failed with:
ValueError: Challenge did not pass for ucs.domain.de: {u’status’: u’invalid’, u’challenges’: [{u’status’: u’invalid’, u’validationRecord’: [{u’‘: u’*ttp://ucs.domain.de/.well-known/acme-challenge/oLama9QXW84Vt44Mz7uwi_NymRpoqIlYMG43UXEqZjI’, u’hostname’: u’ucs.domain.de’, ***
why is http used? >>*ttp://ucs.domain.de/<<
Do i have to forward port 80 to ucs?
Afaik the ucs lets encrypt app only supports the http challenge, so yes.
