Hi, can I rename Domain network name?
I cannot do it by portal
Regards
Regards
after installation you can not rename the domain name at all. Sorry for this.
/CV
I’ve not change Domain name only Networks name, see attach
HI,
got it. And no, a rename is not possible either. Delete the network and re-create them. There should not be any depending objects so far.
/CV
@Christian_Voelker Thank you
