Need SuiteCRM for UCS 4.4-9 errata1333
i had to reinstall suireCRM because of some problems during the last Release update to errata1333.
So i saved the DB first and then deinstalled theApp.
Unfortunately, this App is now not longer shown inside the App Catalog for 4.4-9 errata1333.
Is there any way to get the docker image of the last suiteCRM Version to get the problem solved?
