Nagios Problem after Update UCS V4.3 - HTTP WARNING
After the 4.3 Update of the UCS Server I have this Nagios warning:
WARNING: HTTP WARNING: HTTP/1.0 400 Ungültige Anfrage - 655 bytes in 0.019 second response time
Can anyone help me to solve the problem?
Thanks a lot
Stefan
I’ve got these too. They are the results from the CUPS test. Cups and its web interface work, however.
Any ideas ?
Martin
same problem fixed 2017?
https://forge.univention.org/bugzilla/show_bug.cgi?id=44095
greetings
Stefan
Anybody out here who’s able to fix this ?
Martin
Hey,
this seems to be a bug in the CUPS NRPE check: CUPS doesn’t seem to support HTTP 1.0 anymore (which the check_http command uses by default). Adding -S 1.1 to the check_http command line in /usr/lib/nagios/plugins/check_univention_cups fixes the issue for me.
I’ve opened bug 46698 for this.
Kind regards,
mosu
Thanks a lot.
That fixed the problem for me also
Yes, thank you. Finally these nagging e-mails stop. :grinning:
Martin
Errata 169 was released today which fixes this problem.
