Since UCS Update in February Nagios does not start anymore.
Before it was running fine.
If I try to start the service manually I see this:
root@s1:~# service nagios3 start
Job for nagios3.service failed. See 'systemctl status nagios3.service' and 'journalctl -xn' for details.
root@s1:~# systemctl status nagios3.service
● nagios3.service - LSB: nagios host/service/network monitoring and management system
Loaded: loaded (/etc/init.d/nagios3)
Active: failed (Result: exit-code) since Mo 2018-03-12 08:58:19 CET; 11s ago
Process: 9395 ExecStart=/etc/init.d/nagios3 start (code=exited, status=1/FAILURE)
Mär 12 08:58:19 s1 nagios3[9395]: Total Errors: 1
Mär 12 08:58:19 s1 nagios3[9395]: ***> One or more problems was encountered while running the pre...ck...
Mär 12 08:58:19 s1 nagios3[9395]: Check your configuration file(s) to ensure that they contain valid
Mär 12 08:58:19 s1 nagios3[9395]: directives and data defintions. If you are upgrading from a previous
Mär 12 08:58:19 s1 nagios3[9395]: version of Nagios, you should be aware that some variables/definitions
Mär 12 08:58:19 s1 nagios3[9395]: may have been removed or modified in this version. Make sure to read
Mär 12 08:58:19 s1 nagios3[9395]: the HTML documentation regarding the config files, as well as the
Mär 12 08:58:19 s1 nagios3[9395]: 'Whats New' section to find out what has changed.
Mär 12 08:58:19 s1 nagios3[9395]: errors in config! ... failed!
Mär 12 08:58:19 s1 nagios3[9395]: failed!
Hint: Some lines were ellipsized, use -l to show in full.
root@s1:~#
Any hints how i can figure out the error to get the service up again?
Would be nice if anyone can help me.
Thanks
Stefan
