Nagios Container
Moin,
we create under UCS 4.4-0 Errata 33 with the web interface a CHECK_DOVECOT nagios check. It was stored in the root container:
dn: cn=CHECK_DOVECOT,dc=firma,dc=de
but it should be stored under:
dn: cn=CHECK_DOVECOT,cn=nagios,dc=firma,dc=de
the menu entry to move to an other container is greyed out.
A workaround is to add this check via Domain -> LDAP Directory.
How can we change the storage container?
That is a known bug: https://forge.univention.org/bugzilla/show_bug.cgi?id=49594
I do not have a workaround at hand, the bug report has a patch that may help.
