Move UCS 4.4 Master and Members to faster Hardware
I using UCS a long time ago. Now I want to change the hardware to a faster machine. The “old” hardware is outdated. How can I upgrade the domain master and the different member server without reinstall all domain settings (Users, Files, ownCloud so.)
depends somehow on your Linux knowledge.
You should be able to move your servers to new hardware. Just shut down UCS, start through a Linux Rescue/ Live DVD and copy all files over… start the new machine and hope everything went well. Might be some issues with modules and Grub but should be doable. You need to have Linux knowledge, though…
If your prefer it to do in a different way there is an article regarding single server backup and restore. Just use internet search function.
Third option is backup2master- install a new backup on your new hardware, configure it accordingly your master and doe backup2master. Then decommission old master and you’ll be fine.
/CV
