Monitoring RAID with Nagios
Advise please. Which command name and $arg$ should I set to monitor state of mdadm raid on UCS master server?
Tried “check_univention_i2oraid_physical” and “/dev/md2”, but got std error.
Thank you
Why you aren’t using the standard check “UNIVENTION_RAID”?
Don’t have it in the list of nagios plugins, in Apps - Nagios
You have to install it manually:
univention-install univention-nagios-raid
Solved, thank you SirTux.
