i have the folloewing Problem:
I used to have UCS (4.1-5) connected to Office365 via a Delta sync and the AD-Connector.
After a failed Upgrade to a newer Version, i had to restore my installation from an Backup. This led to my Delta Sync not working anymore.
I upgraded my restored System to Version 4.4-5 and i use The Office 365 Connector now, unfortunately i can not alter the already existing Users in AD.
Following error is in the listener.log
26.08.20 09:06:00.080 LISTENER ( PROCESS ) : o365: Modifying user with object_id u’81ecb576-a974-45ff-b67f-5b25160b4920’ (defaultADconnection) and modifications {‘otherMails’: [‘sth@domain.com’, ‘alias@domain.com’, ‘alias@domain.com’, ‘testest@domain.com’, ‘philipp.wieseckel@mail.domain.com’, ‘philipp.wieseck
el@domain.com’, ‘alias3@domain.com’, ‘ppwieseckel@domain.com’, ‘konferenz@domain.com’], ‘userPrincipalName’: ‘philipp.wieseckel@domain.com’}…
26.08.20 09:06:00.238 LISTENER ( PROCESS ) : o365: status: 404 (FAIL) Code: Request_ResourceNotFound (PATCH https://graph.windows.net/f041a75f-617d-4fa3-8d89-99e9a4c18ae8/users/81ecb576-a974-45ff-b67f-5b25160b4920?api-version=1.6)
26.08.20 09:06:00.238 LISTENER ( ERROR ) : o365: Resource ‘81ecb576-a974-45ff-b67f-5b25160b4920’ does not exist or one of its queried reference-property objects are not present.
File “/usr/lib/univention-directory-listener/system/office365-user.py”, line 465, in handler
modify_user(ol, dn, new, old)
File “/usr/lib/univention-directory-listener/system/office365-user.py”, line 317, in modify_user
ol.modify_user(old, new)
File “/usr/lib/pymodules/python2.7/univention/office365/listener.py”, line 313, in modify_user
return self.ah.modify_user(object_id=object_id, modifications=attributes)
File “/usr/lib/pymodules/python2.7/univention/office365/azure_handler.py”, line 372, in modify_user
return self._modify_objects(object_type=“user”, object_id=object_id, modifications=modifications)
File “/usr/lib/pymodules/python2.7/univention/office365/azure_handler.py”, line 369, in _modify_objects
return self.call_api(“PATCH”, url, modifications)
File “/usr/lib/pymodules/python2.7/univention/office365/azure_handler.py”, line 230, in call_api
raise ResourceNotFoundError(response, adconnection_alias=self.adconnection_alias)
univention.office365.azure_handler.ResourceNotFoundError: Resource ‘81ecb576-a974-45ff-b67f-5b25160b4920’ does not exist or one of its queried reference-property objects are not present.
