Mobile devices to OX
Hi@all,
I have installed a working OX in a test environment. I migrated mails, contacts and calendar data from the ‘old’ system for testing. I have set up mail sending and receiving.
I would like to test the connection of mobile devices (Android / iOS). Do I need to set up anything to use ActiveSync in OX or does it work out-of-the-box? Or it’s better to use the native OX-App?
with best
sven
Hi @pixel,
in android I would use an app like davx5. The UCS OX Installation should have carddav and caldav enabled by default.
cheers
Sebastian
I have set up ActiveSync. Works :slight_smile:
