ich versuche gerade unter UCS 3.2-5 eine Migration auf Samba 4. Auf dem Master gab es anfänglich Probleme, ein manuelles Aufrufen der Join-Scripte lief dann allerdings durch. Windows-Login und Dateizugriff funktionierte auch anschließend.
Beim DC Backup ist es leider problematischer. Der Aufruf der Join-Scripte schlägt fehl:
WARNING: It is not possible to install a samba 4 domaincontroller
into a samba 3 environment. samba4/ignore/mixsetup is true.
Continue as requested
Not updating samba4/role
Multifile: /etc/samba/smb.conf
Object exists: cn=Builtin,dc=top2,dc=top1
WARNING: cannot append cn=backup,cn=dc,cn=computers,dc=top2,dc=top1 to hosts, value exists
No modification: cn=Enterprise Domain Controllers,cn=groups,dc=top2,dc=top1
Stopping Samba AD DC daemon: samba nmbd.
Setting kerberos/kdc
Setting kerberos/kpasswdserver
File: /etc/krb5.conf
Setting slapd/port
File: /etc/init.d/slapd
Multifile: /etc/ldap/slapd.conf
Setting slapd/port/ldaps
Restarting ldap server(s).
Stopping ldap server(s): slapd ...done.
Check database: ...done.
Starting ldap server(s): slapd ...done.
extract_rIDNextRID: Attribute rIDSetReferences not found
Create windows/wins-support
ERROR: Invalid IP address 'top2.top1'!
Forest : top2.top1
Domain : top2.top1
Netbios domain : TOP2
DC name : master.top2.top1
DC netbios name : MASTER
Server site : Default-First-Site-Name
Client site : Default-First-Site-Name
workgroup is TOP2
realm is top2.top1
checking sAMAccountName
Adding CN=BACKUP,OU=Domain Controllers,DC=top2,DC=top1
Adding CN=BACKUP,CN=Servers,CN=Default-First-Site-Name,CN=Sites,CN=Configuration,DC=top2,DC=top1
Adding CN=NTDS Settings,CN=BACKUP,CN=Servers,CN=Default-First-Site-Name,CN=Sites,CN=Configuration,DC=top2,DC=top1
Adding SPNs to CN=BACKUP,OU=Domain Controllers,DC=top2,DC=top1
Setting account password for BACKUP$
Enabling account
Calling bare provision
No IPv6 address will be assigned
WARNING: No path in service IPC$ - making it unavailable!
NOTE: Service IPC$ is flagged unavailable.
Schema-DN[CN=Schema,CN=Configuration,DC=top2,DC=top1] objects[402/1550] linked_values[0/0]
Schema-DN[CN=Schema,CN=Configuration,DC=top2,DC=top1] objects[804/1550] linked_values[0/0]
Schema-DN[CN=Schema,CN=Configuration,DC=top2,DC=top1] objects[1206/1550] linked_values[0/0]
Schema-DN[CN=Schema,CN=Configuration,DC=top2,DC=top1] objects[1550/1550] linked_values[0/0]
Analyze and apply schema objects
Partition[CN=Configuration,DC=top2,DC=top1] objects[402/1614] linked_values[0/0]
Partition[CN=Configuration,DC=top2,DC=top1] objects[804/1614] linked_values[0/0]
Partition[CN=Configuration,DC=top2,DC=top1] objects[1206/1614] linked_values[0/0]
Partition[CN=Configuration,DC=top2,DC=top1] objects[1608/1614] linked_values[0/0]
Partition[CN=Configuration,DC=top2,DC=top1] objects[1614/1614] linked_values[28/0]
Partition[DC=top2,DC=top1] objects[98/98] linked_values[32/0]
Partition[DC=top2,DC=top1] objects[500/502] linked_values[0/0]
Failed to apply records: ../ldb_tdb/ldb_index.c:1216: Failed to re-index objectGUID in CN=Authenticated Users\0ACNF:c38a4bb4-0493-4470-a69a-11b75067c8ea,CN=Groups,DC=top2,DC=top1 - ../ldb_tdb/ldb_index.c:1148: unique index violation on objectGUID in CN=Authenticated Users\0ACNF:c38a4bb4-0493-4470-a69a-11b75067c8ea,CN=Groups,DC=top2,DC=top1: Entry already exists
Failed to commit objects: WERR_GENERAL_FAILURE
ERROR(<type 'exceptions.TypeError'>): uncaught exception - Failed to process chunk: NT_STATUS_UNSUCCESSFUL
File "/usr/lib/python2.6/dist-packages/samba/netcmd/__init__.py", line 175, in _run
return self.run(*args, **kwargs)
File "/usr/lib/python2.6/dist-packages/samba/netcmd/domain.py", line 560, in run
machinepass=machinepass, use_ntvfs=use_ntvfs, dns_backend=dns_backend)
File "/usr/lib/python2.6/dist-packages/samba/join.py", line 1220, in join_DC
ctx.do_join()
File "/usr/lib/python2.6/dist-packages/samba/join.py", line 1102, in do_join
ctx.join_replicate()
File "/usr/lib/python2.6/dist-packages/samba/join.py", line 842, in join_replicate
replica_flags=ctx.domain_replica_flags)
File "/usr/lib/python2.6/dist-packages/samba/drs_utils.py", line 256, in replicate
schema=schema, req_level=req_level, req=req)
Provision OK for domain DN DC=top2,DC=top1
Starting replication
Replicating critical objects from the base DN of the domain
Join failed - cleaning up
removing samaccount: CN=BACKUP,OU=Domain Controllers,DC=top2,DC=top1
Deleted CN=BACKUP,OU=Domain Controllers,DC=top2,DC=top1
Deleted CN=NTDS Settings,CN=BACKUP,CN=Servers,CN=Default-First-Site-Name,CN=Sites,CN=Configuration,DC=top2,DC=top1
Deleted CN=BACKUP,CN=Servers,CN=Default-First-Site-Name,CN=Sites,CN=Configuration,DC=top2,DC=top1
Failed to join the server master.top2.top1.
EXITCODE=1
RUNNING 97univention-s4-connector.inst
EXITCODE=already_executed
Samba4 backend database not available yet, exiting joinscript 98univention-samba4-dns.
EXITCODE=1
Fr 17. Apr 14:15:51 CEST 2015
Man beachte den kleinen Unterschied von den Tips
