mailPrimaryAddress not synced to local ldap from ActiveDirectory
UCS is member server in server 2016 windows AD. AD-sync works but local UCS ldap does not show attribute mailPrimaryAddress even though connector logs a change. Any ideas?
I set mustermann@customerdomain.de in Field E-Mail in AD. Domain is set in UCS:
mail/hosteddomains: customerdomain.de customer.local
If i change users mail-addy in AD, connector.log even shows:
LDAP (PROCESS): sync to ucs: [ user] [ modify] uid=mustermann,cn=users,dc=CUSTOMER,dc=local
So it’s noticed, but not written to LDAP:
univention-ldapsearch uid=mustermann
does not show any attribute with mail (not mail, not mailPrimaryAddress).
Any ideas?
I am having this same issue at the moment. did you check the value of connector/ad/mapping/user/primarymail in your UCS variables? mine was set to false, I changed it to true but the primaryemail is still not syncing.
Thanks for your answer. It’s already set to true here.
Just reported here:
https://forge.univention.org/bugzilla/show_bug.cgi?id=51647
