Moin,
habe ein Problem mit UCS, Kopano und z-push.
UCS: 4.1-4 errata489
Kopano: 8.1.1.10-8.1-3
z-push: 2.3.7
23/01/2018 10:12:25 [11393] [FATAL] [angelique] Fatal error: /usr/share/z-push/lib/wbxml/wbxmldecoder.php:440 - Allowed memory size of 134217728 bytes exhausted (tried to allocate 41355976 bytes) (1)
23/01/2018 10:12:25 [14432] [ERROR] [angelique] LoopDetection->ProcessLoopDetectionPreviousConnectionFailed(): Command 'SendMail' at 23/01/2018 10:11:25 with pid '14432' terminated unexpectedly or is still running.
23/01/2018 10:12:25 [14432] [ERROR] [angelique] Please check your logs for this PID and errors like PHP-Fatals or Apache segmentation faults and report your results to the Z-Push dev team.
Kann mir da jemand was zusagen, bzw etwas auf die Sprünge helfen?
Ach ja, memory_limit 1024M in der /etc/php5/apache2/php.ini
ebenso in der /etc/z-push/apache2.conf
Vielen Dank
Willy
