UCS uses logrotate to rotate the log files (see UCS manual, ucr search logrotate and man logrotate for details).
UCS 4.x
- In UCS 4.4,
logrotateis invoked via a daily cronjob:
$ ls -l /etc/cron.daily/
-rwxr-xr-x 1 root root 377 Aug 29 2018 logrotate
cron.dailyruns by default at06:25in the morning:
$ cat /etc/crontab
# Example of job definition:
# .---------------- minute (0 - 59)
# | .------------- hour (0 - 23)
# | | .---------- day of month (1 - 31)
# | | | .------- month (1 - 12) OR jan,feb,mar,apr ...
# | | | | .---- day of week (0 - 6) (Sunday=0 or 7) OR sun,mon,tue,wed,thu,fri,sat
# * * * * * user-name command to be executed
25 6 * * * root test -x /usr/sbin/anacron || ( cd / && run-parts --report /etc/cron.daily )
UCS 5.x
- In UCS 5.0, we still have a daily cronjob for
logrotate, but this is only a fallback:
$ cat /etc/cron.daily/logrotate
#!/bin/sh
# skip in favour of systemd timer
if [ -d /run/systemd/system ]; then
exit 0
fi
- What takes priority, is a new
systemd timer:
$ systemctl list-timers
NEXT LEFT LAST PASSED UNIT ACTIVATES
Thu 2021-12-16 00:00:00 CET 12h left Wed 2021-12-15 00:00:01 CET 11h ago logrotate.timer logrotate.service
- This still runs the same
logrotateconfiguration, but the execution time has changed. By default, thesystemd timerforlogrotatenow runs at midnight (00:00)!
How to change the logrotate systemd timer execution time
In some cases, 00:00 might be a really bad time to do logrotating, especially if the rotation also triggers restarts of services. In this case, we can modify the execution time of the logrotate.timer:
- We create a custom timer config via:
systemctl edit logrotate.timer
- This will create a new file
/etc/systemd/system/logrotate.timer.d/override.confthat allows us to overwrite the default execution time - After running
systemctl edit logrotate.timer, add the following to the now open file:
[Timer]
OnCalendar=
OnCalendar=*-*-* 06:25:00
- The first line clears the entry (
daily) from the default config, the second line sets the new time - Then save and close the file
- Verify with
systemctl cat logrotate.timer:
$ systemctl cat logrotate.timer
# /lib/systemd/system/logrotate.timer
[Unit]
Description=Daily rotation of log files
Documentation=man:logrotate(8) man:logrotate.conf(5)
[Timer]
OnCalendar=daily
AccuracySec=12h
Persistent=true
[Install]
WantedBy=timers.target
# /etc/systemd/system/logrotate.timer.d/override.conf
[Timer]
OnCalendar=
- Afterwards, a
systemctl list-timersshould show us the correct NEXT execution time:
Thu 2021-12-16 06:25:00 CET 18h left Wed 2021-12-15 12:05:26 CET 1min 28s ago logrotate.timer logrotate.service
