Just decommissioned a Primary node and have a few bits in LDAP that need to be changed.
Current entry:
# failover, ucs-9410, dhcp, fqdn.com
dn: cn=failover,cn=ucs-9410,cn=dhcp,dc=fqdn,dc=com
dhcpMaxClientLeadTime: 600
objectClass: dhcpFailOverPeer
dhcpFailOverSecondaryPort: 5020
dhcpFailOverSplit: 128
dhcpFailOverSecondaryServer: 10.0.1.238
dhcpFailOverPrimaryPort: 5019
dhcpFailOverPrimaryServer: 10.0.1.231
cn: failover
How do I change the dn: entry to:
dn: cn=failover,cn=ucs-9412,cn=dhcp,dc=fqdn,dc=com ??
I’ve attempted the change using
changetype: moddn
newrdn: cn=failover,cn=ucs-9412
However, it errors out with an Invalid DN syntax.
Using just the cn=ucs-9412 replaces the cn=failover with:
cn=ucs-9412,cn=ucs-9410,cn=dhcp,dc=fqdn,dc=com
For anyone who bumps into this issue as well, here’s what I did and the LDAP syntax needed to accomplish the change.
Create New DHCP Service
Create a new DHCP Service entry for the server replacing the decommissioned Master/Primary. This is accomplished in the LDAP web interface in UCM. Your {base_dn} → dhcp, + ADD.
Under Add a new LDAP object, chose Type DHCP: Service.
Enter your new server host name in the ‘Service name’ field and ‘Create LDAP Object.’
Modify Existing LDAP Entry
kinit Administrator
oldHost={your decommissioned server host name}
newHost={your new Primary server host name}
ldapmodify -Y GSSAPI <<_LDIF_
dn: cn=failover,cn=$oldHost,cn=dhcp,dc=domain,dc=tld
changetype: moddn
newrdn: failover
deleteoldrdn: 1
new superior: cn=$newHost,cn=dhcp,dc=domainname,dc=tld *<-- replace with your particulars*
_LDIF_
If everything goes well, your get a response similar to:
modifying ran of entry "dn: cn=failover,cn=ucs-9410,cn=dhcp,dc=domain,dc=tld"
The old Service record for the decommissioned can be removed.
The final step is to update the dhcpFailOverPrimaryServer: entry.
In this case, I used
ldapmodify again.
dn: cn=failover,cn=$newHost,cn=dhcp,dc=domainname,dc=tld
changetype: modify
replace: dhcpFailOverPrimaryServer
dhcpFailOverPrimaryServer: {IP Address of new Primary Host}
_LDIF_
Restart DHCP Service
On both servers:
systemctl restart isc-dhcp-server.service
Hope this helps.
