i tried Softerra LDAP Browser and i see that for example Group “Domain Admins” not have “all” Users:
here you can see only 5 members… but in real we have a bit more:
and “Domain Users” should have all Users, but also not more than 5:
what could be the reason for?
Thx!
Erik
Can I suggest you try using:
“Apache directory studio”
see if the results are the same.
I find it very suspicious the list is always 5 item max…
i dont think its a problem of softera, in other groups are more users:
apache directory studio look same:
now you know it’s not the SW, its time to crack open the logs
in
/var/log/
/var/log/univention
i cant find currently any problem in logs… BUT i checked ldap browser with port 7389 instead normal 389 and there all groups are correct:
can you point me to correct log file?
Thx!
Erik
i’d go thru all the log files looking for errors,
since , I know it works, because on my system I see the groups and members of >85 with no problem.
so something strange is going on with what you see…
