ldap filter stopped working after ucs 5.2.2 update
I was using ldap filter to allow access only to members of a group to the ocs inventory system, but after the update from 5.X to 5.2.2 it stopped working? What should I do?
follows filter:
Thank you very much, I did the procedure mentioned and it worked. In version 5.2-2 errata157. it seems that they fixed this problem. Once again, thank you very much.
