Language setting
We would like to make a default langue to French Switzerland. We try to add variable ucs/server/languages/fr_SC but it is not working. in fact we do not know what is Swiss french language variable is.
Many thanks
Jean-Raoul
first part of the variable is the language and the second the country.
So for you it would be fr_CH (I would have guessed you know the country code where you live in…)
I am just unsure if this would be enough. You can have the UMC (webFrontend) in French, too. But you have to select it during installation. Have you configured correct language settings during installation? What does
ucr search ucs/server/languages
print? And what is the output of
ucr search locale
/CV
Many thank and yes it is working with fr_CH.
Kind regards,
Jean-Raoul
