SERVICE DISCOVERY
The service discovery feature allows back ends to automatically find the appropriate servers to connect to using a special DNS query. This feature is not supported for backup servers.
Configuration
If no servers are specified, the back end automatically uses service discovery to try to find a server. Optionally, the user may choose to use both fixed server addresses and service discovery by inserting a special keyword,
“_srv_”, in the list of servers. The order of preference is maintained. This feature is useful if, for example, the user prefers to use service discovery whenever possible, and fall back to a specific server when no servers can
be discovered using DNS.
The domain name
Please refer to the “dns_discovery_domain” parameter in the sssd.conf(5) manual page for more details.
The protocol
The queries usually specify _tcp as the protocol. Exceptions are documented in respective option description.
See Also
For more information on the service discovery mechanism, refer to RFC 2782.
Yes, should work, but, no not really. I’ve tested it on us environments. Maybe Windowsclients do use this. But not Linuxclients. You don’t notice it because the sssd caches everything. But there is no Kerberosticket.
I spend time on this project, and tested it here on my env. And no, without extra entries, there is no redundants. My whole report and my working configfiles here in my Wiki:
