Hi@all,
I have recently reissued the UCS member on the Kopano running. Everything worked out fine.
I have the packages:
- Kopano Core
- Kopano Webapp
- Z-Push for Kopano installed
Enter the support key and activate the repos. Afterwards Kopano updates were offered.
When I open the settings in Webapp Z-Push is missing:
If I look on another server Z-Push is listed here:
the packages are installed:
root@saturn:~# dpkg -l | grep kopano
ii kopano-backup 8.7.12.0-0+21.1
ii kopano-client 8.7.12.0-0+34.1
ii kopano-common 8.7.12.0-0+34.1
ii kopano-dagent 8.7.12.0-0+34.1
ii kopano-dagent-pytils 8.7.12.0-0+21.1
ii kopano-gateway 8.7.12.0-0+34.1
ii kopano-ical 8.7.12.0-0+34.1
ii kopano-lang 8.7.12.0-0+34.1
ii kopano-monitor 8.7.12.0-0+34.1
ii kopano-python-utils 8.7.12.0-0+21.1
ii kopano-search 8.7.12.0-0+21.1
ii kopano-server 8.7.12.0-0+34.1
ii kopano-server-packages 8.7.12.0-0+34.1
ii kopano-spooler 8.7.12.0-0+34.1
ii kopano-webapp 4.0.2740+113.1
ii kopano-webapp-plugin-desktopnotifications 2.0.3.26+32.3
ii kopano-webapp-plugin-filepreviewer 2.2.0.26+24.3
ii kopano-webapp-plugin-files 2.1.5.305+101.2
ii kopano-webapp-plugin-filesbackend-owncloud 2.1.0.87+42.5
ii kopano-webapp-plugin-filesbackend-smb 2.1.0.50+31.5
ii kopano-webapp-plugin-folderwidgets 4.0.2740+113.1
ii kopano-webapp-plugin-mdm 3.0.133+47.1
ii kopano-webapp-plugin-smime 2.2.2.240+24.3
ii kopano-webapp-plugin-spell 2.0.0.19+37.5
ii kopano-webapp-plugin-spell-de-de 2.0.0.3+34.4
ii kopano-webapp-plugin-spell-en 2.0.0.1+34.4
ii kopano-webapp-plugin-spell-nl 2.0.0.1+35.4
ii kopano-webapp-plugin-titlecounter 4.0.2740+113.1
ii kopano-webapp-plugin-webappmanual 4.0.2740+113.1
ii kopano4ucs 1.6.2
ii kopano4ucs-app 1.6.2
ii kopano4ucs-lib 1.6.6
ii kopano4ucs-schema 1.6.2
ii kopano4ucs-udm 1.6.2
ii kopano4ucs-webapp 1.6.6
ii kopano4ucs-z-push 1.5.33
ii libgsoap-kopano-2.8.101 2.8.101-0+1.1
ii libvmime-kopano3 0.9.2.96+3.1
ii php-kopano-smime 1.0.00+6.1
ii python3-kopano 8.7.12.0-0+21.1
ii python3-kopano-search 8.7.12.0-0+21.1
ii python3-kopano-utils 8.7.12.0-0+21.1
ii z-push-backend-kopano 2.5.2+0-0
ii z-push-kopano 2.5.2+0-0
ii z-push-kopano-gabsync 2.5.2+0-0
I don’t know if this is related but I have problems with the Outlook connection on this system. In User -> Kopano I have activated “Outlook over ActiveSync-Access” and connected Outlook with OL-Connector.
The folders I see with this user in Webapp:
I do not see in Outlook:
