Kopano Webapp Login picture
after the last update of my kopano webapp I can see a new login picture.
Is there a way to change this?
Best regards,
Stefan
Hi @r100gs,
the background picture is part of the theme of WebApp. You could create your own theme with your preferred background and set it as default in config.php.
Ok, thank you.
I will try to create my own theme
