Kopano ical - SSL not working
I figured out that kopano-ical seems not be able to read the certificate key file. The domain.key file has 0640 rights for root. May I change the rights manually and will this work without any issues to other services or is there something not like expected with kopano-ical?
Kopano ical log
Starting kopano-ical version 8.7.0 (pid 13609 uid 998)
ECChannel::HrSetCtx(): cannot open key file
Error loading SSL context, ICALS will be disabled: call failed (80004005)
Kopano ical config
# File with RSA key for SSL
# Warning: the value "ssl_private_key_file" has been set via UCR variable "kopano/cfg/ical/ssl_private_key_file"
ssl_private_key_file = /etc/univention/letsencrypt/domain.key
# File with certificate for SSL
# Warning: the value "ssl_certificate_file" has been set via UCR variable "kopano/cfg/ical/ssl_certificate_file"
ssl_certificate_file = /etc/univention/letsencrypt/signed_chain.crt
Andy
Hi @raceface2nd,
the Kopano user is missing read permissions on the configured files (or the paths leading up to it).
Hi @fbartels,
Quick question . . . I added read permissions for the kopano user by using setfacl now. Do I have to repeat this when I change the config for letsencrypt?
Andy
I can’t say. I don’t know how the lets encrypt app is creating these files.
Understand, the weird thing for me is that kopano-ical was the only service with this issue. All other services do not have this issue.
