hello everyone, I would like to install kopano on the debian buster (nginx and php 7.3) but using ucs for management. Is it possible to install only the management part with the schema extension? if yes, which package should be installed?
thank you.
Hi @bbassotti,
while you can install just the umc integration (so that you can manage your Kopano users through the Univention UI, the needed packages are documented in https://stash.z-hub.io/projects/K4U/repos/kopano4ucs/browse/docs/just-integration.md), you have to be aware that this is not the primary goal of the integration/app and that you are missing out on automatic configuration of Kopano.
One other thing I should add: there are currently no officially supported packages for Debian Buster (yet).
thanks, buster has kopano in standard repositories:
I know. Still, these are not officially supported packages (as in supported by Kopano)
