After updating kopano does not start anymore. I get this message:
“K-2170: soap_ssl_server_context: SSL/TLS error (Can’t find or read certificate in private key PEM file). OpenSSL says: (null).”
in /etc/kopano/ssl are 3 files:
-rw-r----- 1 kopano kopano 5340 Nov 26 2019 cert.pem
-rw------- 1 kopano kopano 1679 Nov 26 2019 private.key
-rw------- 1 kopano kopano 7019 Nov 26 2019 server.pem
both pem-Files are SHA1-encrypted. Could this be the problem? How to solve this?
cd /etc/kopano/ssl/
cat private.key > server.pem
cat cert.pem >> server.pem
change owner
cd /etc/kopano/ssl/
chown kopano:kopano *
Restart kopano-server and check status
systemctl restart kopano-server
systemctl status kopano-server
First (before the update), I had to re-create all SSL certificates:
eval "$(ucr shell domainname ssl/default/days)"
cd /etc/univention/ssl
for i in *".${domainname}"; do univention-certificate new -name "$i" -days "${ssl_default_days}"; done
And then follow all other steps of Renewing the SSL certificates (but use univention-certificate new instead of univention-certificate new as shown above)
