i use Univentionserver and Kopano (without Desktopapp), Z-Push and Outlook 365 and my Problem is, that i can’t send files with 75MB. They got rejected because of “queue filesize limit exceeded”
I tested it at the moment only with the Kopano Webapp.
I don’t know which variable i have to change for the queue file size, if not the ones i did changed?
If its only my problem i would use owncloud or whatever to send big files (we got the technology), but this is at the moment not possible.
Maybe someone has a tip for me (German or English)
-UCS-Version-
4.4-8 errata1146 (Blumenthal)
-UMC-Version-
11.0.6-17A~4.4.0.202108311507
-Kopano Core-
8.7.1.0-1
-Kopano Webapp-
3.5.14.2539-2
I changed the ucr Variable to 100MB
mail/localmailboxsizelimit 104857600
mail/messagesizelimit 104857600
and all php.ini files i can find on my server, as i know from other threats i only need to change the apache2/php.ini (but i was desperate)
$ grep -Hirn upload_max_filesize /etc/php/7.0/
/etc/php/7.0/cli/php.ini:809:upload_max_filesize = 100M
/etc/php/7.0/apache2/php.ini:809:upload_max_filesize = 100M
/etc/php/7.0/cgi/php.ini:809:upload_max_filesize = 100M
$ grep -Hirn post_max_size /etc/php/7.0/
/etc/php/7.0/cli/php.ini:656:post_max_size = 100M
/etc/php/7.0/apache2/php.ini:656:post_max_size = 100M
/etc/php/7.0/cgi/php.ini:656:post_max_size = 100M
no php5 installed (don’t know why “Conflicts: php5” appears?)
$ dpkg -l | grep ‘libapache2-mod-php’ && cat /etc/apache2/mods-enabled/php*load
ii libapache2-mod-php7.0 7.0.33-0+deb9u12 amd64 server-side, HTML-embedded scripting language (Apache 2 module)
Conflicts: php5
Depends: mpm_prefork
LoadModule php7_module /usr/lib/apache2/modules/libphp7.0.so
I also changed this file: /usr/share/kopano-webapp/.htaccess
Both mod_php5.c and mod_php7.c
php_value post_max_size 100M
php_value upload_max_filesize 100M
The mail.log ( $ tail -f /var/log/mail.log ) shows
> Jan 19 21:56:50 JR-VM-UCS01 kopano-spooler[8847]: Starting kopano-spooler version 8.7.1 (pid 8847 uid 998)
> Jan 19 21:56:53 JR-VM-UCS01 postfix/smtpd[8855]: connect from localhost[127.0.0.1]
> Jan 19 21:56:53 JR-VM-UCS01 postfix/smtpd[8855]: 8E33A504B72: client=localhost[127.0.0.1]
> Jan 19 21:56:53 JR-VM-UCS01 postfix/cleanup[8859]: 8E33A504B72: message-id=<kcis.B6556C0815F742C1925CA7F467719B5B@JR-VM-UCS01>
> Jan 19 21:56:55 JR-VM-UCS01 postfix/smtpd[8855]: warning: 8E33A504B72: queue file size limit exceeded
> Jan 19 21:56:55 JR-VM-UCS01 kopano-spooler[8847]: SMTP: Error while executing command 'DATA'. Response: 552 5.3.4 Error: message file too big
> Jan 19 21:56:55 JR-VM-UCS01 postfix/smtpd[8855]: disconnect from localhost[127.0.0.1] ehlo=1 mail=1 rcpt=1 data=0/1 quit=1 commands=4/5
> Jan 19 21:56:55 JR-VM-UCS01 kopano-spooler[8847]: E-mail for user X.XXX could not be sent, notifying user: cancel message (40580)
Can anyone sense a Mistake, except that i am not experienced enough?
thanks in advanced for any hint i get.
