Hello all,
while testing the update from 5.0-10 to 5.2, the pre-update checker complained about the “translog” schema and pointed to the article UCS update fails with verify_translog_schema
The article contains a link to a script that should rectify the problem. That script seems to be somewhat incomplete:
- First, it contains some magic with
slapcatandslapaddwhich would require slapd to not be running - Later, it contains a call to
univention-translogthat requires slapd to be running.
I spotted the slapadd in the script and stopped slapd before running the script, but then the tool threw a stack trace with the gist ‘cant contact LDAP server’.
Could somebody with the right privileges either correct the script or clarify how it is intended to be used?
Many thanks.
