KEY TABS TO SWITCH TO CONSOLE from Graphic Mode
Good day,
CTRL+ALT+F1 used to be a way to change from graphic mode to terminal mode on linux. How do I change my display to console on Univention without rebooting the machine.
Rolanod
Hey,
the X server is probably running on the first console instead of the seventh. Try Ctrl+Alt+2 through 6 instead.
m.
Thanks Moritz,
    Seems the problem is related to an usb keyboard and usb mouse not being recognized when graphic mode loads up.
   Any parameter that we can pass to the boot options to make it go directly to console login?
Thanks,
Riley
