Hallo Allerseit,
ich habe soeben eine komplett nackte UCS Installation durchgeführt. Danach habe ich das AddOn “Active-Directory-Verbindung” hinzugefügt und wollte einer bestehenden AD Domäne auf einem Windows Server 2012 r2 beitreten. Nun bekomme ich immer diese Fehlermeldung:
[quote]Die Ausführung des Kommandos adconnector/check_domain ist fehlgeschlagen:
File “/usr/lib/pymodules/python2.7/univention/management/console/base.py”, line 282, in execute
function(self, request)
File “/usr/lib/pymodules/python2.7/univention/management/console/modules/decorators.py”, line 188, in _response
return function(self, request)
File “/usr/lib/pymodules/python2.7/univention/management/console/modules/decorators.py”, line 316, in _response
result = _multi_response(self, request)
File “/usr/lib/pymodules/python2.7/univention/management/console/modules/decorators.py”, line 460, in _response
return list(function(self, iterator, *nones))
File “/usr/lib/pymodules/python2.7/univention/management/console/modules/decorators.py”, line 282, in _fake_func
yield function(self, *args)
File “/usr/lib/pymodules/python2.7/univention/management/console/modules/adconnector/init.py”, line 377, in check_domain
admember.check_ad_account(ad_domain_info, username, password)
File “/usr/lib/pymodules/python2.7/univention/lib/admember.py”, line 235, in check_ad_account
lo_ad.lo.sasl_interactive_bind_s("", auth)
File “/usr/lib/python2.7/dist-packages/ldap/ldapobject.py”, line 892, in sasl_interactive_bind_s
res = self._apply_method_s(SimpleLDAPObject.sasl_interactive_bind_s,*args,**kwargs)
File “/usr/lib/python2.7/dist-packages/ldap/ldapobject.py”, line 860, in _apply_method_s
return func(self,*args,**kwargs)
File “/usr/lib/python2.7/dist-packages/ldap/ldapobject.py”, line 236, in sasl_interactive_bind_s
return self._ldap_call(self._l.sasl_interactive_bind_s,who,auth,RequestControlTuples(serverctrls),RequestControlTuples(clientctrls),sasl_flags)
File “/usr/lib/python2.7/dist-packages/ldap/ldapobject.py”, line 106, in _ldap_call
result = func(*args,**kwargs)
LOCAL_ERROR: {‘info’: ‘SASL(-1): generic failure: GSSAPI Error: Miscellaneous failure (see text) (Matching credential (ldap/dhcp.fritz.box@FRITZ.BOX) not found)’, ‘desc’: ‘Local error’}
[/quote]
Noch zum Verständnis des Netzwerkes:
Der Univention läuft auf einer Virtuellen Maschine auf einem VMWare. Der Windows-Server läuft ebenfalls auf dieser VMWare. Der WindowsServer vergibt DHCP Adressen und ist gleichzeitig DNS.
Beide laufen auf einer Fritzbox auf woran die Clients angeschlossen werden.
bei der Fritzbox ist DHCP DEAKTIVIERT!!!
Nun verstehe ich nicht warum er trotzdem versucht mit der Fritzbox zu arbeiten.
Könnt ihr mir weiterhelfen?
