Hi everyone,
I’ve joined my Ubuntu/Fedora/etc workstation using SSSD to UCS. The issue is that they currently shows up as “Windows Workstation/Server” under the type column of the Computer menu/list.
I had previously tried the Univention client on Ubuntu 18.04, and that column was set correctly when using the Univention client. Thus, the client must be setting something that allows UCS to set the type as Ubuntu/Linux. I tried to look through client code to see what value is being set so that this is displayed correctly, to no avail.
Does anybody know where this info/value is stored? I’d love it if SSSD would work correctly for this, as I’d like to reliably join more than just Ubuntu as a Linux client.
Cheers
