Hi there,
after a release upgrade on our domain controller there are three join scripts pending and executing (or force executing) fails.
The pending join scripts are:
- 30univention-appcenter failing with:
Waiting for activation of the extension object 66univention-appcenter_app: ...ERROR: Master did not mark the extension object active within 180 seconds.
ERROR
ucs_registerLDAPExtension: registraton of /usr/share/univention-appcenter/66univention-appcenter_app.acl failed.
EXITCODE=1
335fd8ec-ee93-4bcd-97e8-872f06e2d959
- 40unvention-virtual-machine-manager-schema failing with:
Waiting for activation of the extension object univention-virtual-machine-manager: ...ERROR: Master did not mark the extension object active within 180 seconds.
ERROR
ucs_registerLDAPExtension: registraton of /usr/share/univention-ldap/schema/univention-virtual-machine-manager.schema failed.
__JOINERR__:FAILED: /usr/lib/univention-install/40univention-virtual-machine-manager-schema.inst
EXITCODE=1
4ab6ed17-7fdb-4df9-b779-34321d19499e
- 97univention-s4-connector failing with:
Waiting for activation of the extension object s4_connector: ...ERROR: Master did not mark the extension object active within 180 seconds.
ERROR
ucs_registerLDAPExtension: registraton of /usr/lib/python2.7/dist-packages/univention/admin/syntax.d/s4_connector.py failed.
Waiting for activation of the extension object msgpo: ...ERROR: Master did not mark the extension object active within 180 seconds.
ERROR
ucs_registerLDAPExtension: registraton of /usr/share/univention-s4-connector/ldap/msgpo.schema failed.
EXITCODE=1
02caee50-001e-4894-adc5-747354688161
Can anyone help me out? I’m a little bit lost.
