JOIN SCRIPTS 65univention-ox.inst
When performiing join scripts 65univentin-ox.inst Fails with EXITCODE=1 . By the logs is not clear why
# tail -50 join.log
open-xchange daemon must now be restarted if already running
ox-server-install: Setting up UCR...
Setting ox/cfg/AdminUser.properties/CHECK_USER_UID_FOR_NOT_ALLOWED_CHARS
Setting ox/cfg/AdminUser.properties/PRIMARY_MAIL_UNCHANGEABLE
Setting ox/cfg/AdminUser.properties/USERNAME_CHANGEABLE
Setting ox/cfg/cache.ccf/jcs.auxiliary.LTCP.attributes.TcpServers
Setting ox/cfg/cache.ccf/jcs.auxiliary.LTCP.attributes.UdpDiscoveryEnabled
Setting ox/cfg/configjump.properties/URL
Setting ox/cfg/foldercache.properties/ENABLE_INTERNAL_USER_EDIT
Setting ox/cfg/Group.properties/CHECK_GROUP_UID_FOR_NOT_ALLOWED_CHARS
Setting ox/cfg/imap.properties/com.openexchange.imap.spamHandler
Setting ox/cfg/mailfilter.properties/SIEVE_CREDSRC
Setting ox/cfg/mailfilter.properties/SIEVE_LOGIN_TYPE
Setting ox/cfg/mail.properties/com.openexchange.mail.adminMailLoginEnabled
Setting ox/cfg/push-udp.properties/com.openexchange.push.udp.senderAddress
Setting ox/cfg/sessiond.properties/com.openexchange.sessiond.maxSessionPerUser
Module: ox-config
Restarting univention-directory-listener daemon.
ok: run: univention-directory-listener: (pid 9443) 0s, normally down
done.
ox-server-install: Restarting Open-Xchange daemons...
Waiting up to 300s for Open-Xchange daemons to be re-started...Restarting Open-Xchange: Stopping Open-Xchange: open-xchange.
Starting Open-Xchange: open-xchange.
open-xchange.
300 295 290 285 280 275 270 265 260 255 250 245 240 235 230 225 220 215 210 205 200 195 190 185 180 175 170 165 160 155 150 145 140 135 130 125 120 115 110 105 100 95 90 85 80 75 70 65 60 55 50 45 40 35 30 25 20 15 10 5 FAILED
ox-server-install: Open-Xchange daemon failed to restart.
65univention-ox.inst: Failed to setup new installation.
EXITCODE=1
Sat Apr  2 11:32:18 EST 2016
               Please advice on how fix this pending join script.
thanks,
Rolando Riley
The join script is waiting for the OX server to start. It seems it is is not doing that. Please check if there is a java process running:
ps ax | grep xchange
Please look at the log files in /var/log/open-xchange/
Maybe you can identify the reason for the OX server not running.
If you want to try to run the join script again, run univention-run-join-scripts
Hi Throeder,
Open-Xchange is running while doing this process. The only message I see on open-xchange.log.0 is
WARN: [127.0.0.1]:5701 [mail.MYDOMAIN.com] [3.5.2] No join method is enabled! Starting standalone
RR
is the system running fine at the moment or do you encounter edditional issues? Did the OX-Logs only tell you the already sent errors?
Unfortunately we cannot point to a solution with the given information at the moment. Did you contact OX, or can you contact OX at this issue additionally?
Kind Regards,
Jens Thorp-Hansen
