Join script fails 98univention-samba4-saml-kerberos.inst
I am unable to run the last join script. I have read several posts and tried several solutions to no avail. The user-sso not found began after the upgrade to 4.3 from 4.2. there are no rejects and packages are all installed to the best of my knowledge
RUNNING 98univention-samba4-saml-kerberos.inst
2018-03-17 13:55:47.557558436-07:00 (in joinscript_init)
Waiting for user replication...
ERROR: User ucs-sso not found
EXITCODE=1
following a different thread I tried to make sure packages are installed
root@ucs1:/home/dmadmin# dpkg -l univention-saml univention-server-master
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name                     Version           Architecture      Description
ii  univention-saml          5.0.4-17A~4.3.0.2 all               Integrates simpleSAMLphp Identity Provider into UCS
ii  univention-server-master 13.0.0-2A~4.3.0.2 all               UCS - master domain controller
ucr get server/role
domaincontroller_master
 univention-ldapsearch uid=ucs-sso dn
# extended LDIF
# LDAPv3
# base <dc=sgvfr,dc=lan> (default) with scope subtree
# filter: uid=ucs-sso
# requesting: dn
# ucs-sso, users, sgvfr.lan
dn: uid=ucs-sso,cn=users,dc=sgvfr,dc=lan
# search result
search: 3
result: 0 Success
# numResponses: 2
# numEntries: 1
root@ucs1:/home/dmadmin# univention-s4search cn=ucs-sso dn
# Referral
ref: ldap://sgvfr.lan/CN=Configuration,DC=sgvfr,DC=lan
# Referral
ref: ldap://sgvfr.lan/DC=DomainDnsZones,DC=sgvfr,DC=lan
# Referral
ref: ldap://sgvfr.lan/DC=ForestDnsZones,DC=sgvfr,DC=lan
# returned 3 records
# 0 entries
# 3 referrals
root@ucs1:/home/dmadmin# univention-s4connector-list-rejected
UCS rejected
S4 rejected
There may be no rejected DNs if the connector is in progress, to be
sure stop the connector before running this script.
        last synced USN: 22927
I"m not sure what else I should look at, any help appreciated.
very odd… running
/usr/share/univention-s4-connector/resync_object_from_ucs.py --filter uid=ucs-sso
and trying the join script again passed… i wonder if it was blocked by other errors i manged to clear from the diagnostics. either way this can be closed.
that does not work for me
2018-10-05 15:32:40.545703232+02:00 (in joinscript_init)
/usr/lib/univention-install/98univention-samba4-dns.inst: Zeile 42: Warnung: command substitution: ignored null byte in input
Samba4 backend database not available yet, exiting joinscript 98univention-samba4-dns.
EXITCODE=1
2018-10-05 15:32:41.355817133+02:00 (in joinscript_init)
/usr/lib/univention-install/98univention-samba4-saml-kerberos.inst: Zeile 41: Warnung: command substitution: ignored null byte in input
EXITCODE=1
Fr 5. Okt 15:32:54 CEST 2018
Hey,
please don’t hijack threads, especially if the provided solution doesn’t work for you. All it does is lead to confusion, and the original thread’s creator might not be interested in your problem at all. Create a new thread instead, please. Thanks.
m.
