i had a stuck notifier ID on my master DC. After i solved this, i had to rejoin all memberservers and backup DC.
Now i cant rejoin (Version 4.4-2).
I tried this: Problem: Join Script fails on ucs_registerLDAPExtension, e.g. 30univention-appcenter fails on UCS 4.4
of @Christian_Voelker.
The IDs are the Same:
DC Master
DC Backup and Memberserver
I removes the udm setting on dc master and backup:
root@central:~# udm settings/udm_syntax remove --dn=“cn=app_syntax,cn=udm_syntax,cn=univenti
on,dc=c-lab,dc=one”
Object removed: cn=app_syntax,cn=udm_syntax,cn=univention,dc=c-lab,dc=o
root@alpha:/var/log/univention# udm settings/udm_syntax remove --dn=“cn=app_syntax,cn=udm_sy
ntax,cn=univention,dc=c-lab,dc=one”
rejoin command:
Search LDAP binddn: done
Running pre-joinscripts hook(s): done
Running 01univention-ldap-server-init.inst skipped (already executed)
Running 02univention-directory-notifier.inst skipped (already executed)
Running 03univention-directory-listener.inst skipped (already executed)
Running 04univention-ldap-client.inst skipped (already executed)
Running 05univention-bind.inst skipped (already executed)
Running 08univention-apache.inst skipped (already executed)
Running 10univention-ldap-server.inst skipped (already executed)
Running 11univention-heimdal-init.inst skipped (already executed)
Running 11univention-pam.inst skipped (already executed)
Running 15univention-directory-notifier-post.inst skipped (already executed)
Running 15univention-heimdal-kdc.inst skipped (already executed)
Running 18python-univention-directory-manager.inst skipped (already executed)
Running 20univention-directory-policy.inst skipped (already executed)
Running 20univention-join.inst skipped (already executed)
Running 22univention-directory-manager-rest.inst skipped (already executed)
Running 26univention-nagios-common.inst skipped (already executed)
Running 30univention-appcenter.inst failed (exitcode: 1)
Running 30univention-nagios-client.inst skipped (already executed)
Running 33univention-portal.inst skipped (already executed)
Running 34univention-management-console-server.inst skipped (already executed)
Running 35univention-appcenter-docker.inst skipped (already executed)
Running 35univention-management-console-module-appcenter.inskipped (already executed)
Running 35univention-management-console-module-diagnostic.iskipped (already executed)
Running 35univention-management-console-module-ipchange.insskipped (already executed)
Running 35univention-management-console-module-join.inst skipped (already executed)
Running 35univention-management-console-module-lib.inst skipped (already executed)
Running 35univention-management-console-module-mrtg.inst skipped (already executed)
Running 35univention-management-console-module-quota.inst skipped (already executed)
Running 35univention-management-console-module-reboot.inst skipped (already executed)
Running 35univention-management-console-module-services.insskipped (already executed)
Running 35univention-management-console-module-setup.inst skipped (already executed)
Running 35univention-management-console-module-sysinfo.instskipped (already executed)
Running 35univention-management-console-module-top.inst skipped (already executed)
Running 35univention-management-console-module-ucr.inst skipped (already executed)
Running 35univention-management-console-module-udm.inst skipped (already executed)
Running 35univention-management-console-module-updater.instskipped (already executed)
Running 35univention-server-overview.inst skipped (already executed)
Running 36univention-management-console-module-apps.inst skipped (already executed)
Running 40univention-virtual-machine-manager-schema.inst skipped (already executed)
Running 81univention-nfs-server.inst skipped (already executed)
Running 90univention-bind-post.inst skipped (already executed)
Running 91univention-saml.inst skipped (already executed)
Running 92univention-management-console-web-server.inst skipped (already executed)
Running 98univention-pkgdb-tools.inst skipped (already executed)
Running post-joinscripts hook(s): done
The Problem isnt solved
Waiting for activation of the extension object app_syntax: …
…ERROR: Master did not mark the extension object active within 180 seconds.
ERROR
ucs_registerLDAPExtension: registraton of /usr/share/univention-appcenter/app_syntax.py failed.
The Master DC only restore the File:
Before i removed:
root@central:~# udm settings/udm_syntax list
DN: cn=app_syntax,cn=udm_syntax,cn=univention,dc=c-lab,dc=one
active: FALSE
data: […]/F3JFOFCQQcs3AQ==
filename: app_syntax.py
package: univention-appcenter
packageversion: 8.0.11-69A~4.4.0.201909201702
ucsversionend: None
ucsversionstart: None
After i rejoined:
active: FALSE
ucsversionend: None
Active is “FALSE” by rejoin a memberserver. Force the appcenter script on master didnt work too.
Any Ideas?
